Can one of you gurus rescue me from my brain
BigMiIke
It seems pretty simple. I have an iPad that is capable of playing high resolution, audio 192.
I would like to get that audio into my Onkyo 9.2 avr.
I bought an Apple usb - c adapter with hdmi & usb out .
I ran it to my avr - it’s not showing input 192.
It says output 2.1,( because I turned off Atmos )
How can I do this ?
What do I need ?
Is it possible?
Do I need a DAC ? iPad to DAC to receiver ? Is that potentially redundant?
I have an Apple TV but that caps @‘48
Qobuz app sounds great caps @ 96
Any help would be appreciated
'output 2.1' tells nothing about the sample rate
And how much 192kHz/24 content are you realistically going to be able to store on your iPad?
Anyway, none of those number reductions are likely to matter.
How can I do this ?
What do I need ?
Is it possible?
Can the Onkyo do 192? Many video related audio systems are limited to 48. Which by the way - is enough for full transparency for human hearing. So I'd not worry about it.
Well Apple offers 192 streaming - when you click that audio option it actually says you’ll need a DAC to hear it.
My question is, the receiver already has a dac correct?
I’m just trying to hear 192 on my speakers .
Storage isn’t really an issue since it’s Apple Music stream.
And airplay does not play hi res
Good question- Onkyo 797 trying to find that info is very niche
OK, no storage problem then. But is the 'stream' actually 192 kHz in any meaningful way - as in, content with a bandwidth anywhere near 96 kHz, so it *requires* as 192kHz sample rate? And then there's the fact that you can't really hear anything above ~20kHz anyway
I would hope so.
Good luck with that. But I'm telling you, it's OK if it's downsampled to less than 192.
What do you expect "192" will "sound" like?
If you bring an analog signal from the DAC, Onkyo has nothing to do in the digital domain.
That would depend input/mode in an avr, most convert for any kind of processing.
