Exprymer
- Joined
- Apr 26, 2021
- Messages
- 33
- Likes
- 47
Hello, guys, I've been hearing the ~240hz ressonance on this LSR305 MK1 cabinet for years now and today i found the culprit.
Turns out it's not the cabinet, but the plastic holder around the speaker that vibrates.
Method of testing:
I pick up an oscilator from the DAW and swept the frequency until the cabinet started emitting high frequency content because of the plastic holder. When i put my fingers on the plastic the noise would go away.
Simple solution:
Take the correct tool for the screws and instead of tighten them, loosen them a little bit until the ressonance goes away. The noise is entirely correlated to how tighten or loose the screws are.
Difficult solution: Maybe i will design another holder or put some neoprene stuff behind the original holder to mitigate completely the vibration.
This problem has been going around since the first years of production as the link below suggests and i don't know if the MK2 still has the same problem. Still i Hope this little fix can solve it for you too.
See ya!
https://gearspace.com/board/so-much-gear-so-little-time/912092-jbl-cabinet-resonance-anyone.html
Method of testing:
Simple solution:
See ya!
