Building a Revel In-Wall System
kyuu
Greetings all. I will be moving at the end of the year to a new home and am planning out the 5.1 audio system for the living room. I have settled on using in-walls for various reasons: WAF, not taking up floor space, technical advantages (no baffle step), and theoretical advantage of not paying for a fancy cabinet since my budget is ~$500/speaker for the front 3. Even then I will be biding my time waiting for sales and open-box deals to try to shave some more dollars off the budget.
All that said, after spending way too much time doing research (mostly here), I am currently settled on using the Revel W553L for the L/Rs. The trouble I'm having is with the center channel. Initially I was just going to do a third W553L turned horizontally, but of course now I know that an MTM turned horizontally has horizontal dispersion problems. But of course I have the usual center channel problem: it's the most important speaker and I don't want something less capable than the L/Rs, but I have limited vertical space to work with. Since I'm using a wall mounted TV, the W553L in its vertical orientation is simply too tall -- either the TV would be pushed up too high or the speaker would be too low.
So, my options seem to be:
1) Use the W553L horizontally and live with the horizontal dispersion issue. Now, according to Amir's measurements, the horizontal dispersion isn't too bad here:
Plus or minus 20° for a total window of 40° doesn't seem too bad. Here is my current thinking for how the front room will be set up, though of course furniture layout is just a guess and likely not to proper scale (and please forgive my quick Paint 3D job here):
So as you see, I'm currently thinking we'll be about 9 feet back from the screen/center speaker. Assuming I haven't completely forgotten my trigonometry, that gives roughly 3 feet on either side of the "sweet spot" before the holes in the frequency response kick in. Of course anyone sitting on the side sofa will be screwed, but I can live with that.
2) Go with the in-wall equivalent of using a bookshelf for the center. Unfortunately there isn't any data available for the other Revel in-wall options in the same price range outside of their Harman-provided spins, but the spin for the W763 looks pretty good and the price is roughly the same. I can live with its height, and since it would be in its normal vertical orientation the horizontal dispersion should be good out to probably plus or minus 50°. My worry is that, since this is a single 6.5" woofer rather than the dual 5.25", its power handling, distortion, and bass extension won't be up the same level (and again, no actual data to work from). The question is, is this really an issue? I do like to turn the volume up occasionally for movies, games, and music, but I'll be well shy of reference levels and it's going to be handing off sub-80hz duties to the sub. On the other hand, as you can see this is a rather large "great room", although the ceilings are merely standard 8 feet.
Also, Revel claims the 7xx models use "high-output" woofers and tweeters, but without data who knows what, if anything, that actually means.
3) Find a 3-way in-wall speaker from another company to use for the center channel. I haven't seen anything that really qualifies, though, in the price range I'm looking at. It also has to fit in standard 16"-on-center stud bays, as I'm not keen on cutting out studs as part of this install.
4) Relent on the all in-wall and go with a standard boxed speaker for the center. It would be sitting on the entertainment center anyway so it doesn't up floor space regardless. Seems kinda odd to me to have everything in-wall except the center channel, though (plus the sub). Also I'm still in the same situation of finding a good 3-way in my price range.
I also have two other things I'm curious about as part of the install:
1) Is there any consensus as to whether it's advantageous to stuff the relevant wall cavities with some sort of insulation? If so, should it be rock wool, fiberglass, polyfill, something else?
2) The surrounds will be in-ceiling, Revel C363s if that matters (already procured at a good price open-box). These will be open to the attic space that's way larger than a wall cavity... is that going to be any sort of issue? I'm not much of a carpenter, but if it makes sense to build a decent sized box to go behind them I might be open to it. And then again, should the box be stuffed with something?
Thanks in advance to anyone who makes it through my wall of text!
I've seen both of those videos, which part of why I've settled on the W553L as well as why I know that a horizontal 2-way MTM is not optimal. Unfortunately, on their own it doesn't really answer my questions here.
I think #3 and look for the best Vertical Directivity which will be horizontal that you can find and you may pay a little more for something that fits and works. It is only one speaker.
#4 Maybe a very good soundbar for the center channel instead of that big box on your entertainment center.They have come a long way. Search soundbar as center channel. If you are going with an entertainment center put it in not on and the box will disappear. Amir and Erin have tested many SVS, KEF, JBL and RSL make good ones if I recall.
Well, if we ignore options 3 and 4 for the moment... which do you think is less sub-optimal between options 1 and 2?
Well, it's been a lot longer than I anticipated but I've finally gotten part of my system installed. The current state:
Don't yet have an entertainment center, obviously. And the TV is a little off-level, but a couple of screws went missing during the move so I need to figure a way to lock the tilt adjustment. In any case, front LCRs are in place! All that's left beyond furnishings are the in-ceiling surround speakers. Speaking of which, I'm a little uncertain on how to handle the placement.
According to the usual diagrams, rears for a 5.x should be 10 to 30 degrees behind the listening position. However, I'm considering hedging my bets in case I decide to go to a 7.x system in the future. For 7.x, diagrams usually show the side surrounds directly to the sides of the listening position. So should I put them directly to the sides even though it's suboptimal currently, or do maybe 10 degrees behind and accept that the placement is sub-optimal for a future expansion to 7.x? For a 5.x, is going a bit more behind like 20 or 30 degrees better due to the lack of rears?
Hello, I’ve also shortlisted the W553L for my LCR, with the center channel installed horizontally. I came across these speakers through Erin’s review and the discussions here on the forum.
I’m planning a 7.1.4 setup. Before I finalize the purchase, I just wanted to ask—now that you’ve built your system, how are you finding the W553L? What is the performance like? Have you noticed anything about them that could be better. Are there any cons I should be aware of before going ahead? How are the dynamics and how do they perform at high SPL levels?
Also, I was initially planning to use the same W553L for surrounds, but I’m starting to wonder if that might be overkill. Can you suggest me which model I should go for in terms of surrounds and in ceilings?
Thanks in advance!
I'm quite happy with them, and as far as I can tell they handle dynamics and high SPLs extremely well (as the measurements predict). You will need a subwoofer for the last couple octaves. I doubt you could do any better in this price bracket. Speaking of, you can get these for under MSRP through a dealer quite easily (message me if you'd like to know who I went through, they ship to anywhere in the contiguous U.S.).
They probably would be overkill, but a little overkill never hurts. I'm using in-ceilings for my surrounds, a couple of the C363. Work very well. In-ceilings are a compromise, of course, and if you can do surrounds in the wall I would go that route. If you want to save a little, the W363 should do well. I don't recommend the 2xx-series as measurements show that the tweeter in those entry-level ones have some issues.
