One of my friends is embarking on a journey to build a Bessel array using 2x5 pieces of Markaudio CHR-120 drivers
I am posting this on his behalf and with his permission
The sealed cabinet will be designed like this:
Q=0.707, Vb = 76 liters
2x12mm birch plywood potentially with Green Glue or equivalent between the two layers (refer to this:
The drivers have already arrived:
It fits perfectly into a previous cabinet he built for his Alpair 12p drivers
Dirac Live 3 will be used for the optimization
Here are the simulation results:
Showing the -15dB point here since that is likely going to be the 0dB point with his room gain
350W will be the max. input power to reach linear xmax
I will keep on posting updates as he progresses with the build and the measurements
