- Joined
- Oct 3, 2019
- Messages
- 288
- Likes
- 518
Hi all,
I've decided to replace my MM cartridge with an MC and replace my noisy phono pre with a clean, high impedance ribbon mic pre and do RIAA eq digitally.
The mic pre has balanced XLR inputs, while the arm cable currently has single ended RCAs and a ground wire. Ahead of converting the arm cable wiring to fully balanced, can I just use RCA-XLR converter plugs? If so, what do I do with the ground wire?
Thanks in advance,
James
Thanks in advance,
James
