L
Latest activity Postings About
    • L
      Logan Nolag replied to the thread EQ Advice.
      Literally all of the above. It is a desk setup. Speakers are 6" from the front wall and the subs are under the desk. Listening position...
    • L
      Here are the Left Speaker, Right Speaker and Both Speakers together with the MTW Applied.
    • L
      I'm not sure exactly what a 50dB chart is but looking at the post from Keith_W where the scale goes from 50dB - 100dB I assume thats...
    • L
      So I took all the advice from the thread and tried again. I was pretty much able to mostly clean up the crossover dip and I boosted the...
    • L
      I balanced the subs to the mains with the generator and the spl meter and they were the same. Are you really supposed to increase the...
    • L
      Yeah I have two subs. I’m using the RME to cross them over at 80hz. I followed the instructions on their forums to make a 24db...
    • L
      Sure. I had to split the measurements into two files because of the upload limit.
    • L
      So I just picked up an RME 802 FS AE and I’ve been experimenting with its built in Room EQ feature. After several hours of testing in...
  • Loading…
  • Loading…
