NorthSky
- Joined
- Feb 28, 2016
- Messages
- 4,998
- Likes
- 945
That's the same language they use @ Audio/VideoScience forum.
I do think a better enclosure would benefit the kii three and I'd like better drivers but that might well be 'old thinking' .
Good thing I'm not your child...ask my parents.Loving one child doesn't mean you hate the other.
The Kii's are flat to 20Hz not many speakers 'dig deeper' than that, they also do not have the controlled directivity of theKiis.Stereophile's accelerometer test of the DSP'ed, active Dynaudio Focus 200 XD (now revised to the 20 XD) gives practically nothing but deadness:
Given I've had quite a windfall on my home sale, I'm considering going for the Dynaudio Focus XD 60 (or maybe save a bit and get an older XD 600 and apply the firmware update), which cost a few grand more than the Kii Three, but dig a bit deeper in the bass and can be part of a wider Dynaudio Connect wireless system for the whole house.
To a point that's a honest statement, but we went down that road before.The Kii's are flat to 20Hz not many speakers 'dig deeper' than that,
Keith, I'm not denying they can get down to 20hz, easily accomplished with eq.I can show you the measurements of every room here and at customers flat at 20Hz, you need cone area and excursion.
Yes, Peter Aczel once said if woofers were "fast", they would be tweeters. But, I think Sal is correctly pointing to the question of bass output volumes at low distortion. Personally, I would think Kii's would likely benefit from good subwoofers, as would most any other speaker, even many large ones.Slow subs ,quick subs, that's how they think on WBF Sal, unless you r 'quick' subs can play some previously invisible frequencies?
Flat in room means there is no roll-off bass output is exactly as it should be.
The Kiis not only use EQ for the bass, but also motion feedback.But, I think Sal is correctly pointing to the question of bass output volumes at low distortion. Personally, I would think Kii's would likely benefit from good subwoofers, as would most any other speaker, even many large ones.
The notion of "fast" or "slow" could also be related to phase and timing, where "fast" are the ones where all frequencies are pulled into line.Yes, Peter Aczel once said if woofers were "fast", they would be tweeters.
That is a good thing. But, it will not move more air at high volumes compared to larger drivers.The Kiis not only use EQ for the bass, but also motion feedback.
You were talking about distortion. Motion feedback means the distortion is reduced, quite possibly below that of conventional larger drivers up until - of course - the maximum displacement and SPL are reached. If the maximum SPL is adequate, however, then this system will not be distinguishable from a larger driver.That is a good thing. But, it will not move more air at high volumes compared to larger drivers.
Except I was forgetting that phase isn't audible...
Actually, I know a fair bit about the distortion reduction via motion feedback. But, that is not what I was talking about. Rather, it is the maximum SPL. This is where I, Sal too I think, are questioning what the Kii is capable of. As I said, I suspect it cannot move enough air, motional feedback included. I am sure it does great, especially for a stand mounted speaker of its size. I just think it could benefit from one or more good subwoofers, just like most speakers do.You were talking about distortion. Motion feedback means the distortion is reduced, quite possibly below that of conventional larger drivers up until - of course - the maximum displacement and SPL are reached. If the maximum SPL is adequate, however, then this system will not be distinguishable from a larger driver.
Yes, you may well be right - it also uses limiting via the DSP.Actually, I know a fair bit about the distortion reduction via motion feedback. But, that is not what I was talking about. Rather, it is the maximum SPL. This is where I, Sal too I think, are questioning what the Kii is capable of. As I said, I suspect it cannot move enough air, motional feedback included. I am sure it does great, especially for a stand mounted speaker of its size. I just think it could benefit from one or more good subwoofers, just like most speakers do.
Each Kii uses four high excursion drivers , Devialet do much the same with their 'Phantoms'
