At this point I think the OPs desire is one of:
Cheap, beautiful, and long term reliable. Pick any two of these three.
The ones made (or company resides and sells) in western countries are obliged to follow them,so I guess RME,Sciit,etc are following them.
Same goes with the devices officially sold by western companies and shops as they have to follow the rules.
The ones sold by Aliex and the likes only needs searching,at lest the ones using mains power.
Here's an example of one of the amps I'm using,I don't know If all of them are obligatory though.
And I think they are made in Malaysia.
Even Bryston will only give you 5 years on digital products,20 years is only on analog.RME is a 6 year warranty,probably as good as it gets on a digital product,I’d expect it to remain repairable by them for many years longer IF parts are available.
With anything digital based that’s a bloody massive if.
For tech that's still being developled, it is disposable, as they're mostly obsoleted way before any EOL caused by their materials or build. Known tech - analogue amps, wired headphones, turntables, passive speakers (or your woodworking tools example) etc your fine. I wouldn't invest into things like expensive DACs or wireless headphones though, as they'll be obsoleted before their materials fail; and if they do fail, good luck getting the parts as the industry will have moved on.
Hahah you might be on to something.At this point I think the OPs desire is one of:
It is impossible to say at this point. Some established companies have deserved reputations. Some new ones are fantastic, but you won't know until they've been around a number of years. Some you can see as deficient by taking their gear apart or opening them up.Hahah you might be on to something.
I guess I'm also just trying to establish how much money you do have to spend before you can get reliability.
It seems, based on user reviews, that the $200 price point of the Topping 30-line amps and dacs aren't enough to get you reliability... but what about the $500 of the 70-line?
Like, are the middle to middle-upper-tier offerings from any of these brands sufficient to expect a decent lifespan? Maybe not their smallest, cheapest stuff, but what about their middle offerings?
It does not matter if the design is only analogue or an analogue+digital hybrid, if it is designed well enough to be measurably inaudible. If you take an analogue signal and pass it correctly through a well designed modern ADC and then through a well designed modern DAC, you will be unable to hear any difference.The thing is, I'm not familiar enough with audio equipment to be able to tell if something actually is digital or analogue in design.
There isn't such a thing in the 21st century as "digital in design". Good designers use the right tool in the right place. I would never use an analogue equaliser (other than sparing use of low-impact tone controls), the only sensible way to perform EQ these days is mathematically in the digital domain. On the other hand, if I wanted a unity gain buffer, I wouldn't use an ADC and DAC combo.However, once I start seeing digital screens, with equalizers and such, on brands like RME and SMSL and Singxer, I just assume they are more digital in design,
There's a clue right there. Buy something like that from the used market.My dad's audio electronics from Yamaha are 40+ years old and still work just fine with no maintenance.
Just because something has a complex display does not mean the audio has been digitally "interfered with". It's perfectly possible to have an analogue-only chain but still have a processor controlling a rich display or even the volume (e.g. a processor controlled switched relay analogue volume control).
There are no obvious differences there. My hunch is that modern gear is more reliable, but harder to repair. For the digital front end, software support is potentially the weak link.Sorry, I was talking about Digital vs analogue solely in terms of manufacturing reliability, not in terms of audio quality.
Every time a additional physical parameter is added means tools are added or to the service station requirements.There are no obvious differences there. My hunch is that modern gear is more reliable, but harder to repair. For the digital front end, software support is potentially the weak link.
For example.
-Upgrade the PCB from thru-hole to hybrid SMD plus thru-hole.
=Need many more tools both passive and powered plus more experience.
-Add in high power PWM switching devices.
=Need more and different tools again.
Result is that a large comprehensive, expensive lab work station is required with multiple sized solder rework tools, a fume hood, visual magnification system(s) and the list goes on.
That seems a question suitable for a MOD.BTW, I've narrowed my choice of stack down to a few options that I would love for the community to vote on. Would it be inappropriate for me to make yet another post, simply as a poll?
Definitely not. It is made in the same place, from the same components. Recently, several owners here had to send failed devices back for warranty replacement. And this was only after a short period of acquisition.Do you think Schiit is more reliable than these chinese brands?
So, you repair stuff... Great! How does it factor in your question of finding the most reliable product with 15+ years lifespan?I have actually repaired a few of my electronics by re-soldering components that have burnt out or broken off.
I am looking forward to seeing the poll... Maybe, I'll finally understand what is this you are seeking.BTW, I've narrowed my choice of stack down to a few options that I would love for the community to vote on. Would it be inappropriate for me to make yet another post, simply as a poll?
Topping and SMSL have excellent measurements at very competitive prices but in my experience:
Based on that, if I want budget gear I'll go with JDS or Schiit, both of which have great support and none of the issues I've had with SMSL and Topping, but are still competitive on performance & price. Even if their quality isn't any better (and in my experience it actually is better), at least they have excellent warranty support.
- They have software/firmware bugs I haven't encountered with devices from US, Canadian or German companies.
- Their software/firmware updates are poorly supported (one update came through a link here on ASR that a year later never showed up on the company's web site).
- The warranty support is quite poor - buy it through Amazon and at least get 30 days.
- I've had hardware failures after just over a year.
For example, when I found a software/firmware bug in a Topping DAC, it was a real hassle reporting it, only to find that they basically ignored my request and never fixed it. Knowing it would never be fixed, nor did they offer to replace or refund it, fortunately I bought it through Amazon so I returned it. In contrast, when I found a problem with the JDS subjective 3, slightly elevated distortion (-60 dB) in standby mode, they responded immediately, acknowledged the issue, changed the design with a second relay to fix the problem, and sent me a replacement board & parts, all at no charge.
For non-budget "high end" gear, I'd go with US, Canada, Germany or similar country, pay the extra cost for the long-term durability and peace of mind that comes with it. For example my Adcom power amp is 30 years old and still measures & performs like new. My Magnepan speakers are 24 years old and still measure & perform like new. Both companies are still around and reply promptly when I've have questions over the years. Other companies like Bryston, RME, Lake People, etc. have similar high build quality & support.
Regarding the OP's original question, for me it would be RME all the way, no doubt about it.
Are you saying you are after the most durable and serviceable product? This is different from the most reliable product...
From that list, I'd go with the Jotunheim, though if you get it with the internal DAC it will be less expensive. Schiit revised and improved the internal DAC card and it now has similar performance to the Modius. Then you have an AIO (all in one) solution. And with an internal power supply, no wall-warts. This is what I use at work. The only drawback is that the digital input is USB only. Put differently, the advantage to the Modius is that you also get SPDIF (coax & toslink) inputs.Thank you for your feedback.
I've narrowed my list to:
The JDS products are out because they have no matching power amps, or ways to switch off the preamp output when using headphones, and the RME product is beyond my budget, even if I stretch said budget.
- Schiit Modius E + Jotunheim 2 ($850)
- SMSL HO200 / DO200 ($1000)
- Topping L70 / E70 Velvet ($1130)
- SMSL H300 / D300 ($1250)
