Which preset sounds best?
  • 1: ASR
    Votes: 3 11.5%
  • 2: Crinacle
    Votes: 3 11.5%
  • 3: oratory1990 Grapher
    Votes: 4 15.4%
  • 4: oratory1990 PDF
    Votes: 17 65.4%
  • 5: Resolve
    Votes: 0 0.0%
  • 6: rtings
    Votes: 1 3.8%
  • 7: SSN
    Votes: 0 0.0%
staticV3
Here's a little experiment to see which HE400se measurement produces the best EQ preset when corrected to Harman OE2018.
Note that this headphone has impressively low unit variation, which might make deciding rather difficult, so I'm giving you three votes.
The presets can only be used with vanilla Equalizer Apo for Windows. If you're using Peace, then you can disable that temporarily.
Here's how to load the presets and A/B them: YouTube Link
Note that in the video you see me setting the preamp to -8.5dB. Here, -10.7dB are required!
rtings' is the only non-GRAS measurement of the bunch, so I "converted" it to GRAS using Jaakko's case study. However, even after compensation it asked for 20+dB boost above 10kHz, so I cut its preset short at about 9.5k
Please make sure that no other DSP is active while comparing.
In case you're interested, here's why I'm using variable band GEQ instead of PEQ. It produces nearly identical results regardless of sample rate. PEQ doesn't.
If you want to compare EQ On vs EQ Off, then you can toggle just the EQ without the overall volume changing - another advantage over Peace.
Happy listening!
  • HE400se GEQ.zip
GaryH
Filter warping by sample rate is marginal, especially at the lower sample rates:
I'd use PEQ, and just tell people to make sure their sample rate is set at 44.1 or 48 kHz. I'd be more concerned about potential audible ringing when using a 600-band GEQ...
GaryH
Oratory's results differ. Are you sure your methodology is sound? And can you post the individual filters used for the above preset? Anyway as I said, just tell people to make sure their sample rate is set to the standard 44.1 or 48 kHz, problem solved (without introducing possible audible issues related to using GEQ).
GaryH
Well we won't know exactly unless you post the individual filters for the above preset so we can can see whether they're actually a reasonable example. And even better redo it with the exact same single filters as Oratory's examples above to compare like for like.
staticV3
staticV3
I'm not following tbh. What filters? The presets are not based on any parametric filters. It's literally measured FR (+some HF smoothing) minus target FR. Here's oratory's Grapher FR for example:
1. Raw Frequency Response
2. HF Smoothing
3. overlay Harman
4. calculate Error
5. invert Error
And that green graph is literally the graphic equalizer you're applying in EQApo.
staticV3
staticV3
I'm talking about this:
Ah, my bad. Here are the filters:
Filter 1: ON PK Fc 77 Hz Gain 4.0 dB Q 0.15
Filter 2: ON PK Fc 163 Hz Gain -9.6 dB Q 0.70
Filter 3: ON PK Fc 1337 Hz Gain 4.1 dB Q 3.21
Filter 4: ON PK Fc 2513 Hz Gain 7.3 dB Q 1.88
Filter 5: ON PK Fc 3529 Hz Gain -2.4 dB Q 1.14
Filter 6: ON PK Fc 10930 Hz Gain 2.6 dB Q 1.79
Filter 7: ON PK Fc 19886 Hz Gain -7.7 dB Q 0.46
Just a random PEQ I did for someone. And yes, I'm quite sure my methodology is sound.
staticV3
staticV3
Results using the exact same single filters as Oratory above would confirm (or deny) this.
be my guest. You have everything you need to prove my methodology not sound.
GaryH
It's your methodology to confirm or deny by reproducing the results from a professional acoustic engineer, not mine.
staticV3
staticV3
@GaryH
You question my methodology, you claim that PEQ FR depencence on Fs is negligible, you claim that GEQ may produce audible ringing.
I think it's time you put your money where your mouth is back those claims up.
GaryH
The fact that you're unwilling to reproduce professional results to confirm yours is concerning. The onus is on you to backup your claim that your methodology is sound. 'Assume I'm correct until someone else proves me wrong' is not scientific. The scientific way is to first prove and demonstrate your methodology is sound before accepting its results, by making sure it corroborates existing correct results from professionals in the field. There's no way to be 100% sure the conditions, software and hardware I use would be exactly the same as yours so no, I can't do this for you.
staticV3
staticV3
The fact that you're all talk, no substance sure makes me think that I'm wasting my time on someone agruing for argumen't sake.
Here's my methodology: YouTube Link
Measuring the analog output of the DAC as well as using another PEQ program produced identical results btw:
but staying digital is more convenient.
So how would I make 100% sure the conditions, software and hardware I use would be exactly the same as what oratory used?
GaryH
You don't necessarily need to, if your results can replicate his exactly. This should be the first thing you do before presenting any other results.
solderdude
The Neitherlands
I used a treble peak filter and added some low bass. Liked it that way but it is still entry level planar.
So my vote would be none of the above ;-)
staticV3
staticV3
you're actually trolling now, aren't you? What as waste of time.
staticV3
staticV3
I'm not trolling at all. Reproducing prior professional results to confirm a methodology is basic science. The fact that you're spending time with this back and forth but won't do this speaks volumes.
I've shown you the measurements using digital caputure, a four minute video showing exactly how I did that capture, plus a graph showing what the response looks like if instead I capture the analog output using another PEQ program entirely. All of those match each other.
Meanwhile, what have you contributed to this discussion? Any valuable data? Anything at all?
I think it speaks volumes that you're willing to dismiss all of that just because it doesn't match exactly what your favorite internet person once posted. Talk about being scientific :rolleyes:
Music1969
@staticV3 maybe you can try my EQ.
Basically I applied oratory1990's 'linear bass extension' EQ (see the notes in his Sundara PDF) to Crinacle.
To me, this EQ best fits all Sundara measurements I've seen and leaves out the outlier 'issues'
Preamp: -9.0 dB Filter 1: ON LSQ Fc 28 Hz Gain 6.00 dB Q 0.71 Filter 2: ON PK Fc 66 Hz Gain -0.80 dB Q 1.50 Filter 3: ON LSQ Fc 105 Hz Gain 3.50 dB Q 0.71 Filter 4: ON PK Fc 940 Hz Gain -1.0 dB Q 3.70 Filter 5: ON PK Fc 2250 Hz Gain 3.30 dB Q 1.40 Filter 6: ON PK Fc 6105 Hz Gain 2.2 dB Q 1.50 Filter 7: ON HSQ Fc 10000 Hz Gain -1.0 dB Q 0.71
