nerdemoji
- Joined
- Jul 17, 2023
- Messages
- 194
- Likes
- 304
Skip to the bolded text if you don’t care about the story.
Before I learned about audio science, I got the AirPod Max and thought that they were the pinnacle of sound quality (actually there was a recent study that showed they had preference very close to Harman 2018). When I learned some Audio Science, I listened to them with Oratory1990’s EQ settings and they sounded amazing. I learned about speakers, too and thought they would be a good choice to further improve my sound.
When I got speakers (KEF Q150 + SMSL AL200), I was excited and they sounded good but there was some mid bass note that sounded really loud and long. I thought “well I know that it is a room resonance, but I don’t know what frequency it is at and I don’t have a measurement mic”. I had EqualizerAPO installed and could go in and guess the frequency, but then a thought occurred, if it was only 1 note on music, then surely I could go into Tone Generator and find it. Sure enough, I found a huge spike at 130 hz and promptly removed it from using the equalizer and I went into tone generator until it sounded flat. I did the same thing with other smaller bumps in the region and the difference was remarkable.
Time passes, and I was reading a thread and someone mentioned that the LF of a speaker in a room is similar to the HF of a headphone because both are the right wavelength for reflections in their spaces. Because of the 90 degree HRTF being different between people, the same headphone will have peaks and dips that are ear-specific. So, I had an idea. Here was my method.
1: Start with the general EQ to Harman 2018 from Oratory1990, Resolve, Amir, etc. I used EqualizerAPO (Peace GUI).
2: Go into Tone generator
https://www.szynalski.com/tone-generator/
3: Listen to it (from 1khz it should sound like it is rising in volume.) For me peaks and dips started at 4khz. I heard a slight dip at 4khz and a slight bump up at 5khz. A huge dip at 6khz and a big spike at 7-8khz. Big dip at 10khz. Rise after that and roll off at 17khz.
4: Estimate EQ to flatten and test until it sounds smooth (dips might not be removed by EQ in my experience). I didn’t remove the 10khz dip and I didn’t touch anything after 10khz.
5: This part is important. I want to know if this works for more than just me. I had my brother generate a random number 1 or 2 and choose the EQ and play a song of my choice beforehand in the other room. I was able to guess it and found preference in the new one.
If you guys have the time and resources, I would like to know what you guys think of this. If not, is this bad or against science from a conceptual perspective? I heard EQ is “blunt” for headphones at High Frequency. Is this because of the nature of the treble in headphones or content in music or because reviewers didn’t want people to EQ out dips and peaks in their headphones from measurements because the on-head sound would be different in HF for different people?
Lots of questions…
Lots of questions…
