[This thread is now closed as the Tableau dashboards are no longer in service. Please refer to the Master Review Index to see the latest information regarding ASR data + dashboards.]
Hi everyone. I wanted to let folks know about the new Headphones Review Index. It follows the same core structure as electronics and speaker dashboards. You can find it here (or pinned on the Forums main page):
The new index page has the following dashboards which are tabs on the top:
Some key features:
EQ Profiles
This dashboard is based on the headphone EQ filters created by Amir and compiled by member @sweetchaos . To learn about PEQ data input and operation, please use these reference posts:
Some key features:
EQ Software (beta)
This dashboard is based on the EQ software list compile by member @Doodski . To see his full list please use this reference post.
Some key features:
Going forward I'll be maintaining these headphones dashboards. Please PM me (or post on this thread) with:
- Headphone Index
- Notes
Some key features:
- You can click anywhere on a row to jump to the ASR review of the headphones.
- The Tooltip (which you can see if you hover over the Price field on the right) has a layout that includes being able to view the manufacturer's product webpage.
- There are two recommendation fields displayed: with EQ and without EQ. (You can also filter on both types of recommendation.)
EQ Profiles
Some key features:
- The Tooltip (which you can see if you hover over either the Frequency, Gain, or Q fields) will show you the source, a link to the headphone review & measurements, the measurement date, and the measurement rig.
- To see the full text of a profile simply hover over the text in the "Profile Text" column. You can select + copy from the pop-up text box that appears.
EQ Software (beta)
Some key features:
- The Tooltip (which you can see if you hover over the blue/orange square on the far right) will show you additional info about that software application.
- To go to a software application's website simply click on that entry in the table.
- feature suggestions. (Keep in mind that we are limited by what the visualization platform -- Tableau Public -- can do.)
- issues you find with the data.
- issues with the dashboards.
