- Joined
- Aug 3, 2019
- Messages
- 939
- Likes
- 1,449
This thread makes me very glad I power my chip amps with industrial SMPS units rather than what amount to supersized "wall warts" -- I'm just sayin'....
- Cheers!--Fosi Audio V3 Mono Amplifier Review
Our hearing apparatus changes with everything, even during the same day it reacts differently in the morning or in the evening, this affects the way we hear how the speakers sound. Indeed it does.audiosciencereview.com
In order to test such switching power supplies for their performance and reliability, the appropriate equipment and experience is also needed.- Cheers!
So the first point regarding the Fosi Huntkey 48V 10A power brick is at least addressed by Fosi now. It was a short video but definitely helps.
Seems to be that the 'test' was rather rudimentary and says nothing of the brick's continuous (like more than 5 seconds) current output.
However, I'm not an EE. I've got no idea how dependable that testing method used by Fosi for their power supply is though. Anyone have any input there?
- Still hoping some testing results of the Aiyima GaN 10A will be shared here at some point.
You can't get good laboratory power supplies for $100, especially not with an output of 300 to 500 watts.yeah i but i remember i asked about using lab psus... like it doesnt matter if they are a bit ugly and fiddly.... you can get good ones for $100 usd
but few people seem to want a lab psu in their setup
BUT... i mean for 99% of us the 48v 5a is just fine???
eg.
under $25 and brand name
True, but you can sure AF get industrial SMPS units for far fewer $$ per amp than a nominally equivalent "power brick": About $50 for a 48V 10A unit on eBay and even less via AliExpress. Of course a little DIY is required, so don't pursue this alternative unless you understand how to deal with the safety concerns involved -- Amir has admonished me on that point and he was correct to do so.You can't get good laboratory power supplies for $100, especially not with an output of 300 to 500 watts.
Have you ever received or requested documents about these cheap power supplies on Ebay, Aliexpress, etc.?True, but you can sure AF get industrial SMPS units for far fewer $$ per amp than a nominally equivalent "power brick": About $50 for a 48V 10A unit on eBay and even less via AliExpress. Of course a little DIY is required, so don't pursue this alternative unless you understand how to deal with the safety concerns involved -- Amir has admonished me on that point and he was correct to do so.
Yes, like the regular power bricks, but aren't as cheap. Search for instance Meanwell GST360 series.Question: Do any of the industrial SMPS makers offer encased & fully wired products? I'm happy for now using the Fosi and Aiyima bricks as is, don't really want to build a case for a Meanwell (did enough of that with my cigar-box TPA3116 builds)...
These reports are sort of like restaurant reviews on Yelp or some such in that the satisfied users rarely have anything to say and complaints from disappointed users overwhelmingly dominate. Chip amps don't demand anything near the rated current of the PSU for anywhere near as long as a 3-D printer or a big LED array. Such failures are usually heat-related and the one SMPS I own with thermostatically-controlled cooling has never even turned on its fan. Based on that experience, I completely removed the always-on fan from the other SMPS in my system and have had no problems whatsoever ever since.The 3D printing world has reports of the cheap industrial PSUs not being able to make rated output, and failure modes involving flames. I'd say it's worth spending a bit more on a reputable brand with proper certification.
360 Power Brickhttps://www.meanwell.co.uk/power-supplies/external-power-supplies - up to 360W with 3s of short term peaks to 125% of rated power.
And that's exactly where you are completely wrong.BTW, "proper certification" of an industrial subassembly is not the same as for a consumer product like a power brick and assumes that the component will be used internally or otherwise positioned where any naked electrical connections are inaccessible to the end user, so standalone use of such products requires some rudimentary safety savvy.
At least in the U.S. context, this is more myth than fact -- maybe it's true elsewhere, but hereabouts most abodes have dozens of uncertified items from extension cords to nightlights connected up to AC mains without any insurance consequences in the event of a mishap.Of course, you can order and use such power supplies on Aliexpress. But if something happens (fire, personal injury, etc.) you are of course liable and no insurance company will cover it.
Anyone who uses such power supplies should be aware of this.
