cyclo
- Joined
- Apr 1, 2023
- Messages
- 66
- Likes
- 167
To be sure of what?
To be sure of what?
Wait...blocking low frequency noise? When did that start happening?
The ferrite clamps are cheap... The sub cable is long and goes around, over, under other mains cables connected to other components (TV, etc.). Just cheap insurance...Wait...blocking low frequency noise? When did that start happening?
They suppress RF frequencies. Never blindly believe internet BS.
I use them professionally for absorbing RF. I was just quibbling about the Google search result.The ferrite clamps are cheap... The sub cable is long and goes around, over, under other mains cables connected to other components (TV, etc.). Just cheap insurance...
https://www.audiosciencereview.com/...measurement-and-comparison.27937/#post-970936
That's what I personally do but not everybody has soldering skills or the time to build their own custom cables.
Any difference between these cables? Or is it just mainly the looks (colors)?
...Go.It should be noted that any comments or arguments in defence of cable shielding and the resultant benefits are summarily and regularly closed down on this forum.
Which is why I'm not going to bother commenting
Watch for the backlash to even this comment in 3.....2......1.....
Measurable differences between cables are just that, measurable and supportable.It should be noted that any comments or arguments in defence of cable shielding and the resultant benefits are summarily and regularly closed down on this forum.
"even"?Watch for the backlash to even this comment in 3.....2......1.....
But often not significant, as in "usually." The only exceptions are phono cables for MM, where capacitance changes frequency response.Measurable differences between cables are just that, measurable and supportable.
Those are both Star Quad balanced microphone cables. Isn't this about RCA cables.As far as I can tell W2893 has a bit more flexibility and is less microphonic than W2534, but also has more parasitic capacitances.
Other than that, it's just different colors on the jacket. They'll sound exactly the same in all but the most extreme use cases.
Cat is just a cable shill. Preying on the uninformed. Which is why I added him to the "Ignore" list a while ago. I see he still pops up... too bad."even"?
Nobody shuts you down, they just say its useless until you bring some measurements and listening tests. If you consider that 'backlash', you certainly aren't an engineer.
Vaseline? I'm hoping this is a joke.@amirm can you , this is rather odd one , i can do this test myself , but maybe you could ,
string and um, vaseline not to be kinky of course
rub the vaseline onto string and see if it can conduct a voltage or test with voltmeter see if there is any continuity
