The tests below were done to see what the noise rejection of these interconnect cables was to a magnetic field and to compare relative differences between cables and not absolute performance.
All interconnects are unbalanced RCA-to-RCA. The interconnects used were a pair of legendary Belkin Synapse cables. A pair of RG58A/U interconnects were made from West Penn 812 cable. A pair of interconnects were made from Mogami W2534 star-quad cable.
The Synapse and RG58 are coaxial cables with stranded center conductor and braided shield. The West Penn 812 RG58 has an additional Al-polyester-Al foil shield. The Mogami W2534 is of star-quad construction with a single served shield.
Except for the Synapse cable, I made these cables myself. The shield and one pair of the quad conductor W2534 are connected to the signal ground at both ends. The RCA connectors for the RG58 and W2534 were all harvested from old Radio Shack Gold series audio cables. I have reused these connectors several times over for many years. The RCA connectors for the Synapse cable are the original connectors that the cable came with.
The cables are in pairs—meaning there is a left and right channel cable—and both are connected for the test. All the cables are twisted together with the opposite channel cable. The Belkin Synapse cable was a molded parallel cable that I split apart before twisting together again.
Out to in on an old Macbook Pro that has headphone out and line in analog ports. 96 KHz sample rate 24 bit. -0.5 dB output level. 0 dB input level.
Cables were placed parallel to the top, and in direct contact with, a 12 Volt, 1 amp rated AC transformer with a 560 Ω, 10 watt resistive load. The transformer is located at the 1 M mark on the interconnect, half way. The contact area was about two inches long and .75 inches wide. The magnetic field strength generated by the transformer was not measured and is unknown.
West Penn 812 RG58A/U, 2M long, one twist every three inches:
Legendary Belkin Synapse cables, 2M long, one twist every three inches:
Mogami W2534, 2M long, one twist every three inches:
What is seen here is to be expected for electro-magnetic interference caused by the AC mains. The 60 Hz fundamental and odd-order harmonics up the spectrum. The even-order harmonics are buried in the noise floor. REW does not number the harmonics properly because the third harmonic is higher than the 60 Hz fundamental.
Here's the same cables without the transformer:
What we are seeing in the last three graphs is the system noise. It's pushed down some by the FFT gain to see if there is anything down there. The DAC noise shaping can be seen above 30 KHz. There are some spurious tones that also appear in that region. It's all pretty much the same for all three cables as this is a fairly EMI quiet environment when and where the cables were tested.
