Woofer integration into audio system using app and REW.
Marin
Okay, I'll try to explain the astonishing things that defy my reason.
I have towers that are rated 42hz but that is -6 db.
I only know that the 60hz crossover didn't look as good at rew measurements as the 80 and above, not to mention the 40hz.
Sorry, I can't find the pictures.
I mostly tuned the phase to 90hz via REW alligment toola.
I left the fronts at 2.70 as set by YPAO, and I increased the 3 meters for the woofer to 19 meters according to REW?
And really 6 db more at 80 Hz?
Admittedly, my woofer is a small Kenwood and only goes up to 35, but that's exactly what I need to have a flat 40hz bass guitar.
Something that the towers themselves have no chance of doing.
Mostly now the bass seems faster and more tactile, but there is one app and it has an interesting test.
It's called hi-fi subwoofer alligment tool.
In that tesr I can't hear the difference between 0 ms and 100 ms. in hi hat + bass 27hz, and hi hat 40hz.
The difference is more than 30 metars?
I can't believe that I en that deaf?
Or room acoustics have something to do with it?
I posted some pictures of waterfall and it seems that bass takes 20 ms. to "get down."And these are professional studio monitors!
Because that would mean I wouldn't be able to tell the difference between someone saying something from 30 meters and from 1 meter or less?
If someone coude download the app and test it.
It's easy to connect a cell phone with an RCA to headphone cable?
Thanks in advance
