I'm likely building a home theater at some point. The designs are still in the works but the front row might be 12' from the front speakers and the rear row might be 17' from the front speakers. I'm toying with the idea of having bookshelf speakers as LCRs since they're considerably cheaper. For example, the KEF R3 and HDI-1600s are much cheaper than their tower counterparts ($4200/$3750 for three vs. $8100/$7500 - CAD). The sensitivity of the R3 and HDI-1600 compared to the towers is lower by about 1 to 5 depending on the models.
I've looked at loudness using the SPL calculator at https://myhometheater.homestead.com/splcalculator.html
Using the KEF R3 as an example: Two KEF R3s from 17 feet away with 70 watts powering them can produce about 97db. This is not quite reference, but does seem quite loud for peak home theater uses. Or am I wrong?
What are people thoughts on using bookshelves as LCRs? Can they get loud enough? The bookshelves don't go as low but with subwoofers does that become irrelevant?
