hyperplanar
Hey y'all, I was hoping that the members with experience repairing electronics could chime in here.
I bought a SL-1200MK2 secondhand from a local DJ as my first turntable and have been using it for some time now. I decoded the serial number and discovered it's nearly as old as I am
I installed/aligned a new cartridge and also acquired an OEM mat after buying it. For the most part, everything seems to work great; however, the braking function works inconsistently, and trying to fix it has left me scratching my head. To clarify, the braking function is what is activated whenever the stop button is pressed--it applies an impulse of torque in reverse to the platter in order to decelerate it as quickly as possible. The length of the impulse is adjustable using a pot underneath the platter, which I have already tried fiddling with.
The problem is that the braking only works sometimes. About half the time, the braking works properly; a quarter of the time, the braking does not do anything at all, and another quarter of the time, the braking is way too strong and sends the platter spinning backwards.
I have a multimeter and a soldering iron (and I am currently at the point on the Dunning-Kruger scale where I would definitely bust my turntable if I tried to investigate further by myself...)
Your advice is appreciated!
