No sure about slew rate, but Class D easily reach Mhz switching in MOSFET. Of course, the bandwith is already limited by output filer already mention.In layman's terms, does Class D have (dis)advantages with respect to slew rate?
You don't need full 20khz power to get slew limiting. Look at the freq. spectrum of a square wave, the fastest signal, most of the power is in the fundamental.Now, since the power content of recorded music decrease a lot with frequency, an amplifier could be actually works fine even with not sufficient slew rate for 'full power-full frequency operation' (but not completely true for what said by DonH56 about bandwidth limitations).
Slew rate is one of many design variables and the number is just one choice to make. It is impacted by other design issues so does not by itself indicate quality of performance (high or low). Higher slew rate requires higher bandwidth, which means more power, more noise, and potentially greater sensitivity to reactive loads (reduced stability). Higher bandwidth and thus higher slew rate may produce lower distortion (e.g. if higher loop gain and thus more feedback is implemented in the design). High or low slew rate is not necessarily an indicator of audio performance; noise and distortion are better metrics IMO. When I am looking at amplifiers I rarely (or barely) glance at the slew rate (if it is even specified).I am late to this topic
I am comparing the Slew rate of a Hafler Pro5000 to other Hafler amps, and noticed that the slew rate is low
Hafler pro5000 (1991 $1500 ) yes more expensive than the XL-600
SLEW RATE: 1 kHz, 12OV p-p square wave: 40 volts
per microsecond.
Hafler Transnova 9505 ( 1991 $2200 )
150V/us
Hafler XL-600 ( 1989 $1100 )
SLEW RATE: 10 kHz, 130 volts peak-to-peak squarewave: 100 V/us
Why is the pro5000 so low compared to the other amps ?
Is that a sign of low performance ?
Sorry, I have practically no experience with the Hafler Pro amps, they came out after I was working for a store that sold them, and by 1991 I had a new baby boy to keep me busy along with a demanding new job. It has decent specs for the time, but also has a fan for cooling, that may be an issue for home use (if it activates in a quiet room).What do you make of the pro5000 for home audio ?
Very expensive amp back in the day
Can you check the specs and topology?
Thanks for your help
The lowest of those rates would not have a deleterious effect on audio quality. The higher rates simply are not needed for living room audio settings.I am late to this topic
per microsecond.
150V/us
They don't need higher slew rates. Professional amps care about reliability, not impressing marketing with numbers that do not matter in the real world. Higher slew rates require higher bandwidth which usually means higher noise, and that can be a problem for sound reinforcement systems that tend to use horn-loaded compression drivers that are more sensitive than many home speakers. The audience is not interested in hearing hiss. For consumers, higher slew rates well beyond that needed for full-power 20 kHz output is not a plus unless it supports some other metric like lower distortion, noise, etc. For consumers, in terms of audibility, all a high slew rate does is provide a bigger number for marketing and puts more tweeters at risk.I noticed that the Yamaha p2200 40/us and the Crown ps-400 16/us very low.
Do studio amps don’t care about higher rates ?
You could always get a Spectral. 1 mhz bandwidth, and slew rate of 1000 volts/microsecond.I noticed that the Yamaha p2200 40/us and the Crown ps-400 16/us very low.
Get a hold of yourself man. Sounds like you are claiming enough slew rate is enough or some odd idea like that.They don't need higher slew rates. Professional amps care about reliability, not impressing marketing with numbers that do not matter in the real world. Higher slew rates require higher bandwidth which usually means higher noise, and that can be a problem for sound reinforcement systems that tend to use horn-loaded compression drivers that are more sensitive than many home speakers. The audience is not interested in hearing hiss. For consumers, higher slew rates well beyond that needed for full-power 20 kHz output is not a plus unless it supports some other metric like lower distortion, noise, etc. For consumers, in terms of audibility, all a high slew rate does is provide a bigger number for marketing and puts more tweeters at risk.
The Spectral I had hissed audibly. The salespeople were struck with sudden deafness when I pointed it out.You could always get a Spectral. 1 mhz bandwidth, and slew rate of 1000 volts/microsecond.
Kind of odd. I had a DMA 50 and it was dead silent. I knew someone with a DMA 80 with some rather efficient speakers and it also was dead silent. This was back when I my hearing was pretty extended to something like 18 khz. The Spectral amps were straight wire with gain plain and simple.The Spectral I had hissed audibly. The salespeople were struck with sudden deafness when I pointed it out.
You could feed it a PWM signal, add some filtering, and have a Class D ampYou could always get a Spectral. 1 mhz bandwidth, and slew rate of 1000 volts/microsecond.
Demian Martin who designed them has posted here a few times. He said the reason for the wide bandwidth is they wanted extremely fast settling time after a signal has come and gone. I understand that is also what you want for class D. So probably would work just fine.You could feed it a PWM signal, add some filtering, and have a Class D amp![]()
If it's not bad enough to show-up in the distortion measuremets, there's nothing to worry about!Only
23 V/US
very disappointed, all the other specs are good
