Measurements for electrostatic headphone amps? (or energizers)
Fluffy
I really appreciate the good work been done in this site in measuring headphone amps. I am interested in electrostatic headphones, but the problem is there is not much solid information about which amplifier performs objectively better. Stax, for example, sells a whole range of energizers that look pretty much the same, but have drastically different prices.
Are there measurements anywhere of amplifiers\energizers for electrostats? If not, then how come?
The voltages produced may have something to do with it...
https://www.head-fi.org/threads/electrostatic-amplifiers-voltage-ratings.582518/
"3000 volts peak to peak stator to stator (+/-750 power supplies)
KG TOGTE
2400 volts peak to peak stator to stator (+/-600 power supplies)
koss esp950
2300 volts peak to peak stator to stator (+/-575 power supplies)
KG’s new Silicon Carbide jfet based space heater.
2000 volts peak to peak stator to stator (+/-500 power supplies)
Stax T2, DIY T2, KGSSHV (ixys parts)
1800 volts peak to peak stator to stator (+/-450 power supplies)
KGSSHV (sanyo parts)
craig has said his new electra amp does 1800 volts, power supply unknown
Ergo Jecklin "
and so on...
Ok, but if they can make headphones that run with these voltages, then it should be possible to build a measuring device. In the end these are just audio electronics, and they need to obey the same standards as all audio equipment – frequency response, distortions, noise to signal ratios, channel matching, etc. I'm sure the people who build them can measure them, can't they?
KG TOGTE
koss esp950
Ergo Jecklin "
and so on...
what is a togte? i have never seen this on headcase.
Hi guys! I just found an old Japanese site with measurements for electrostatic headphone amplifiers <https://seesaawiki.jp/w/funya2420/>
(The dB figures are from eyeballing the graphs on the site. For the frequency roll off I counted the pixels)
(Edit: Changed DNR to A-Weighted)
