I got a pair of JBL 104 today, and set them up via TRS with an Audiobox GO. Windows 11, USB-A to USB-C, playing FLAC thru MusicBee, also via other music apps.
Also tested with RCA to confirm volume.
It would appear: the volume control is at FSD on the speakers, and the dial on the AudioboxGo is FSD and the volume control in W11 system tray is set to 100%. With an arbitrary Sound Analyzer App using the Samsung S22+, confirmed with another Samsung phone with the same software, the JBL 104 speakers top out at around 77dB at 70cm equal distance.
Tested with: King Crimson, Jimi Hendrix, Pachelbel
The peak SPL is 92dB from the JBL website literature, and 77dB from what would ostensibly be 30W from a class D amplifier, is, basically disappointing.
https://jblpro.com/en/site_elements/jbl-professional-104-spec-sheet
That's effectively giving 1W output. I can measure the actual output at the wire with a DSR and ammeter while playing a 1kHz test tone, and white noise.
Assuming: 1 Watt=77dB, then a 3dB rise for each doubling of power, gives another ~5*3dB=>77dB+15dB=92dB total.
The speakers are certainly clear and a good quality c/w my Sony MDR-V6 headphones, so no complaints there.
Am I doing anything wrong? I read the reviews here a few times.
Cheers
GB
Cheers
GB
