You mean like this?
Whilst the soldering doesnt look good, yes this is correct wiring at the RCA end.
That other coax cable is no good.
I seem to post the following on a daily basis
You mean like this?
Well it doesn't work anyway with the nc502mp With my nc400 I have no problems. Also my point anyway was how would I know if the cable is correct before buying? I can't see any information about this type of stuff before buying cables. And as proven even if you have the "correct" cable it's a no go for the nc502mp.
Its *NOT* normal.f course stuff happens and I have full understanding of that but there are different opinions here on if the buzzing is normal or not. This is what I want to find out.
Did you read Apollons response I posted? I think both Apollon and I thought a wire had come loose or something like that. But according to them, after testing was done, the buzzing is normal and affects all MP modules.
The buzzing should however go away with a balanced connection according to their testing. This I have not personally tested yet.
For EMC reasons, one like to group all inputs and outputs in the same area. The inputs close to mains is a weakness that has a workaround. Other solution would be speaker outputs at this place, but there would be no workaround.At the end of the day, placing the input differential header (with likely 9mm unshielded pins) immediately adjacent to the AC mains and input filtering is just a totally bone-headed design from Hypex.
But in the interests of getting it all on a super compact PCB, stuff like that happens all too often these days. An unterminated input on a powered up amplifier should be silent. Not as silent as a shorted input or a low R source, but there should be no audible hums or buzzes.
Looks like there is no contact between blue/shield of the cable and connector shield. Anyhow, since your amplifier hums when open, I fear that a proper RCA-XLR connector will not solve the issue. I see a problem in the way the module is installed by Apollon.You mean like this?
If you connect 10 cm of a perfectly shielded/twisted cable on the amplifier module and leave it completely open on the other side, you will get clearly audible hum, especially on channel 1.?
Your implication was that as soon as you connect internal wiring they hum. This is not the case.
I have been looking at pictures from the big brother NCMP8350. Build is beautiful, but I wonder how AES48 is handled. Connectors seem to be Neutrik NC3FD-LX series, which do not offer integrated grounding, meaning that pin 1 needs wire connection to the chassis. On the pictures this connection is not visible. The workaround I was talking about does not seem to be applied, explaining the hum when connectors open. Do you have a way to check resistance between pin 1 and case?f course stuff happens and I have full understanding of that but there are different opinions here on if the buzzing is normal or not. This is what I want to find out.
I doI do not.
Glad to see you still have this charming habit to modify your posts after people replied to them.I can't speak for your experience but I do not see this problem and none of our amps buzz with the inputs open.
I do
Before we enter in an endless loop, my youngest son is two, and he is my fourth child. My resistance to the "no" is at it's highest level and I am ready for the Olympics of the affirmation .
Edit
At which point did anybody suggest that your amplifiers would be buzzing? Why being so defensive?
Your amplifiers do not buzz, good for you and your customers. My amplifiers do not buzz either, even without fancy wiring.
Thanks for the video.Fred its not being defensive. I have been simply answering some misconceptions and inaccurate descriptions of the behaviour of the Hypex modules.
If you are having problems with these amp modules buzzing there is something amiss in your set up. I have tested countless of them and they simply dont behave as you describe. A differential input with good CMR shouldnt do so unless there is some "inbalance" in the wiring.
Here is a video to demonstrate with a NC502MP module quickly lashed up on the bench.
With the input connector open there is no buzz.
When I plug in an open balanced cable there is no buzz. I can of course provoke buzz (mains pick) up if I touch either hot or cold leg. I did this just to prove the amp is actually on and connected to the speaker
I have been using these modules for about 3 years and not seen the problem so I dont think there have been any relevant board revisions from Hypex.Thanks for the video.
OP has the problem.
I have the problem with the exact same setup as yours (I watched the video 3 times). I need to do extra wiring to remove the buzz.
Only reason I see is that both the OP and myself are too far away from south pole...
Or that Hypex made changes since I made my tests.
Then that's the south pole proximity.I have been using these modules for about 3 years and not seen the problem so I dont think there have been any relevant board revisions from Hypex.
To be honest I don't know what to make of it all but if I don't have any buzz when I connect the amp to my balanced pre-amp with these cables https://shop.sommercable.com/en/Cab...l-Stage-22-Highflex-SG0Q.html#tab_description then I basically don't care about the other scenarios at this point. Are these also bad cables? I mean I just don't know. Please recommend cables that are compatible if the linked cables are not good - it would not surprise me if even pure XLR cables can be made incorrectly at this point.
One use case that would be good though is if I could have some of the channels unplugged and that not affecting the other channels that are plugged in. I guess I will just have to wait and see. And just to make it more clear I have 21 speakers in my room and some speakers have high sensitivity and I sit quite close to some of them so when stuff starts buzzing it's kind of annoying.
Thank you.
I see your 21 speakers and raise you to 36 speakers (18 pairs), 6 unused powered subwoofers and one centre speaker. And then there's some electronics...
