FWIW from Josh Ricci's data-bass site https://web.archive.org/web/20180130173833/http://data-bass.com/data?page=content&id=79
Yes, you can over-dampen a speaker very quickly...
The basic rule is to use as much damping material as necessary, but as little as possible.
The 1lb/ft^3 they mention is what I usually shoot for. You'll also notice that in Tom Nousaine's experiments I linked in post #35, that was about the optimum stuffing density to minimize Fs.It appears that someone has questions about this quite some time ago:
The Appropriate Use and Effects of Speaker Stuffing - Techtalk Speaker Building, Audio, Video Discussion Forum
I have a very simple question that has me wondering about speaker stuffing - and no, not the kind of stuffing that makes you belch after a meal. I meantechtalk.parts-express.com
Overstuffing? - Techtalk Speaker Building, Audio, Video Discussion Forum
Want a second or third opinion about your speaker cabinet design or other audio related problem? Post your question or comment on the Technical Discussion Board. Hundreds of technicians, engineers, and hobbyists, nationwide read and discuss electronics related questions each week. We welcome...techtalk.parts-express.com
Very interesting! Since you didn't write anything about objective data it seems that you can't measure the positive change right? Can you detect in which frequency range the negative impact happen is it around the resonance frequency of the driver or above?This has been my experience, which includes blind listening tests in the course of product development specifically focused on investigating the type and quantity of damping material for a sealed box.
Ime the most reliable way to fine-tune the amount of damping material can be rather time-consuming, at it involves A/B listening comparisons of two otherwise identical loudspeakers.
Thank you for the links interesting to read. I had read a bit of the threads but I didn't find an answer to my question here regarding potential harm if you don't do crazy stuffing.It appears that someone has questions about this quite some time ago:
audiojudgement.com
In the simplified theory of a speaker as an electric circuit this can be accounted for by changing (lowering) Rm for the mechanical damping.Does anyone know how accurately modify the equivalent circuit to include damping material in the closed box?
Does anyone know the 18" woofer he used in these tests?FWIW from Josh Ricci's data-bass site https://web.archive.org/web/20180130173833/http://data-bass.com/data?page=content&id=79
To dampen means to add moisture to something. To damp means to reduce or discourage something, usually by way of using something dissipative.This has been my experience, which includes blind listening tests in the course of product development specifically focused on investigating the type and quantity of damping material for a sealed box.
Colloquially, yes. Strictly speaking, no.The focus was on the midrange, and I haven't found frequency response measurements to be of much use for evaluating the effects of internal damping material on sound quality in the midrange region.
"Damp" can refer to either moisture or vibration, and likewise "dampen" can refer to either moisture or vibration. In both cases the primary meaning has to do with moisture.
Using something that puts the brakes on boomy sound from my speakers I am all for. Pouring water on them I am not.For many years I would have agreed with you because usage of the term "dampen" in an acoustics context just sounded wrong to me. Then I looked it up.
Imo dictionaries can be wrong, but it's unusual.
@Rick Sykora
I have been looking at the smallest “mini subwoofer” kits on offer at Part Express (say, the smallest 8 inch mini subs) and every time someone asks about stuffing/damping material the staff always answer with:
“Best Answer: We do not recommend it, any kit that requires damping material will have it supplied in the kit.”
While some other folks say they use the usual 1lb stuff parts express already sells and that it works fine.
I dunno… I’ve never built a sub/speaker before.
I’m curious, do you think their staff is technically correct in discouraging people from adding any kind of damping material in their subwoofer kits?
On a small solid cabinet, probably matters less. That said, these are woofers with strong motors, would consider some 3/4" sonic barrier to line the inner walls...
Which specific kit? What are they using to fasten the woofer?
Mainly either the Hi-Output Passive Dayton Audio Reference 8" Mini Subwoofer Kit or Hi-Performance Passive Dayton Audio Ultimax 8" Mini Subwoofer Kit which are sealed subs.
But The Workhorse Passive GRS 8" Mini Subwoofer Kit would also fit in this compact size/form.
So in this model the enclosure is assumed to be bigger with damping material and there are no other changes?This is at the end of the audiojudgement.com article you cite above. Damping is part of the enclosure compliance Cab. Cab is shown here as part of a closed box equivalent circuit…
Note the math under the inductor circled with the dotted lines.
Bill over on Tech Talk pointed out that damping material in a sub box will absorb harmonics, potentially reducing re-radiation from the cone. Might be true, although I've never tested it. I just stuffed my woofer boxes full, even though they cut off at 110Hz.My "folk intuition" tells me that if I'm planning to use the sub only, say, 120Hz and below then adding additional damping material might be of little to no benefit since the driver is only reproducing bass and with little to no midrange energy.
