What universe are you living in? I have personally found bugs in every single C compiler I have ever used. Some are so bad they'll make an anthill blush.Bugs in a modern C compiler? Unlikely.
Fortunately, compcert exists.What universe are you living in? I have personally found bugs in every single C compiler I have ever used. Some are so bad they'll make an anthill blush.
And you're bitching about Linux, of all things. That's some the cleanest and best documented code I've ever seen. It's not perfect, sure, but if that's what you consider bad, I'd (again) like to know what universe you're from.I know. I'm just being difficult. I hate poorly written and documented code, so I take whatever chance I get to bitch about it.
Unfortunately, compcert doesn't implement the full C standard (or didn't last I checked). There's also no guarantee that their formal language specification is actually correct.Fortunately, compcert exists.
CompCert C supports all of ISO C 99, with the following exceptions:
* switch statements must be structured as in MISRA-C; unstructured "switch", as in Duff's device, is not supported.
* longjmp and setjmp are not guaranteed to work.
* Variable-length array types are not supported.
Consequently, CompCert supports all of the MISRA-C 2004 subset of C, plus many features excluded by MISRA (such as recursive functions and dynamic heap memory allocation).
Several extensions to ISO C 99 are supported:
*The _Alignof operator and the _Alignas attribute from ISO C2011.
*Pragmas and attributes to control alignment and section placement of global variables, as well as layout of structs.
*Built-in functions to give access to some processor-specific instructions.
Only fools blindly parrot Dijkstra without understand that goto has its (tiny) place in some situations.You're an advocate of GOTO statements?
When you come across a compiler bug, you have two choices: report it and wait for a fix or work around it in your code. If you hope to release your product any time soon, you'll be opting for the latter (fixes can take years to arrive). That's why large, mature software projects don't tend to trigger many bugs in their primary compiler. If you dump a multi-million line code base on a new compiler, you're quite likely to run into some problems.The universe where I haven't seen or heard of many in C, in multiple million line ++ system software projects.
Oh, good. They've filled in most of the gaps now. I'd still be surprised if their formal models of the language and target machines are perfect, though.Those unimplemented features being quite discouraged for good reasons, I'm not bothered, personally.Code:CompCert C supports all of ISO C 99, with the following exceptions: * switch statements must be structured as in MISRA-C; unstructured "switch", as in Duff's device, is not supported. * longjmp and setjmp are not guaranteed to work. * Variable-length array types are not supported. Consequently, CompCert supports all of the MISRA-C 2004 subset of C, plus many features excluded by MISRA (such as recursive functions and dynamic heap memory allocation). Several extensions to ISO C 99 are supported: *The _Alignof operator and the _Alignas attribute from ISO C2011. *Pragmas and attributes to control alignment and section placement of global variables, as well as layout of structs. *Built-in functions to give access to some processor-specific instructions.
To be fair I found bugs in the IBM COBOL compiler, I wonder if they ever fixed them.What universe are you living in? I have personally found bugs in every single C compiler I have ever used. Some are so bad they'll make an anthill blush.
Say what you want about COBOL, but the code often comes from an era when code reviews were done by technical team leaders who had standards for code, comments and quality, plus COBOL could be made to almost read like English with a bit of work, if you were a bit weird.Oh no, we don't need no stinking comments.
Then you must have led a fairly sheltered life. Compiler bugs are real. Get over it.Haven't in C. In C++, yes, though mostly with libraries, and often because they do things you're not expecting, like forking a thread.
They you must have led a fairly sheltered life. Compiler bugs are real. Get over it.
When they make for the cleanest code, absolutely. Only a fool would suggest otherwise.You're an advocate of GOTO statements?
The language shouldn't be too hard, C's spec isn't ridiculously complex unlike C++ or other "modern" languages. The targets, though, might be trickier; especially something like x86 where some important semantics like the memory ordering model isn't clearly documented. Or where proprietary microcode, backdoor through ring -3 coprocessors and stuff like SMM really control what's happening. I'd trust it more for ARM.Oh, good. They've filled in most of the gaps now. I'd still be surprised if their formal models of the language and target machines are perfect, though.
I do take a perverse pleasure in the use of the odd GOTO, when I know the code is going to be reviewed (never happens these days) by a pedant, if I can find a place to use one where the alternative is ugly or unmaintainable.You're an advocate of GOTO statements?
Modern ARM is also pretty darned complex. It would be interesting to see what could be done with a CPU architecture designed from the ground up using formal specs.The language shouldn't be too hard, C's spec isn't ridiculously complex unlike C++ or other "modern" languages. The targets, though, might be trickier; especially something like x86 where some important semantics like the memory ordering model isn't clearly documented. Or where proprietary microcode, backdoor through ring -3 coprocessors and stuff like SMM really control what's happening. I'd trust it more for ARM.
