Tamp does that.it's making sure there aren't any pockets and distribution is even.
No it does not. Tamp can't distribute well. You have to tap or use wdt. Unless you have a great grinder and great skills, wdt will almost certainly help. And i speak from experience with noticeable improvement (significantly less channeling)Tamp does that.
it doesn't fully. if you use a bottomless portafilter you can see the differences visuallyTamp does that.
In theory I want to agree...Tamp does that.
I'm reminded of a training session where the trainer asked me why I lightly wrapped the handle of the tamper against the edge of the portafilter after I tamped.In theory I want to agree...
In actuality, I think most of us have seen this fail inexplicably if statement were true.
Fixed that for you.They maybe .0005% better than my $5 WDT from aliexpress
I don't have data to back me up, so better be generous. They look cool at leastFixed that for you.
Ah.. Yes... Style over Substance. I get it.I don't have data to back me up, so better be generous. They look cool at least
No I meant the moonraker. I can understand why it can be more consistent than my $5 one, as the needles would touch every place in the basket with a few rotations instead of relying on me doing so. But as I said, way too expensive for what it brings to the tableAh.. Yes... Style over Substance. I get it.
before applying a polishing tamp...
...Tamp does that.
I think it was waaaaay back in 2021; I distinctly recall our resident 'fu manchu' barista chiding us that the process of tamp'g should be minimized.No it does not. Tamp can't distribute well. You have to tap or use wdt. ...
I'm not chiding anybody, today. Just conversing.Let us review dose prep tools:
Let us also add a new-ish tool to the list:
[Youtube is full of taste-comparisons by 'experts']
I use the first 3 tools (above).
I prefer using a wee-bit coarser grind and then compensate with the following:
*During the grinding process - directly into the basket/funnel - I continually tap/rotate the basket.
*Then, I use an adjustable leveler to spread the dose evenly.
*I finish off the dose preparation by using the tamping tool (maximized).
I must be doing it all wrong but we both prefer the results.
"16.6gm dose/24seconds pull/40gm yield" works for my manual-lever machine that I use daily.
We try to slowly sip our shots without any '30 second' rules (in double-wall demi-tasse).
Bolognium! Everyone knows about magical effects of funnel-magnetism which assists generated electrostatics to assymetrically align the grains! Duh!Dosing funnels can be useful to help contain a mess, I would think, much as using a dosing cup. Necessary tools? Not really, but neither do they imply some sort of magic to improve your shot.
I think that will depend on tamp pressure. There really is no structure in coffee grind that is going to withstand a heavy tamp.Tamp can't distribute well
I'll admit to tapping. But I do this to level the grind - perhaps it also evens out the distribution, who knows. Either way, WDT is not used in this house. Life is too damn short - and getting shorter by the day.You have to tap or use wdt
They are not laughing; those are snarls...I've been to numerous coffee shops in Italy - the birthplace of espresso...
I am sure they are laughing about it.
Side tap? I like an occasional side tap for helping distribute a pile of grind.I'll admit to tapping
