Southall-1998
Please accept my apologies for asking this question.
The Topaz AM10 is rated around 35w into 8 ohms. But doesn't say for 4 ohms.
For small or medium sized rooms. Will the AM10 have sufficient power to drive most 2-way bookshelf speakers? Providing the volume is sensible etc.
The speakers in mind are - Dali Oberon 1 and Oberon 3.
Thank you.
Technical specifications:
Power output 35 watts (into 8Ω) THD (unweighted) <0.01% @ 1kHz, 80% of rated power <0.15% 20Hz - 20kHz, 80% of rated power Frequency response (-3dB) 5Hz - 50kHz S/N ratio (ref 1W) >82dB (unweighted) Input impedances 47k ohms Power Amp damping factor >50 Max. power consumption 260W Bass/Treble controls Shelving, ultimate boost/cut +/- 10dB @ 100Hz and 10kHz Dimensions 76 x 430 x 340mm (3.0 x 16.9 x 13.4”) Weight 5.6kg (12.3lbs)
Thank you.
