Beelink Mini S as Plex server bitperfect question
yewneek
So, I've built and successfully configured a Plex-based music/media server on a Beelink Mini S, running WIndows 11 with 1TB SSD for media and 16GB DDR4 for the overhead. Much of my audio is FLAC
Plays fine in 4k streaming, all the clients find it, etc.
How do we know when it's streaming bitperfect? I've got Tidal Hifi Plus hooked into Plex too, all settings to MAX.
I can stream to Chromecast Audio, Plex client on Sony Bravia X94J GoogleTV thru a HTG-700 soundbar on eARC, and to Plex on any of my phones or elsewhere.
The potential is there, just when would it be bitperfect?
TIA
Greg
RayDunzl
Central Scrutinizer
Riverview FL
Basics:
I would expect the bits to be "perfect" if the playback sample rate is the same as the recorded sample rate, and there is no digital volume control applied, and no EQ applied.
What else may go on in your path is unknown to me.
In my case, as I have a little volume cut (bits changed), things get resampled to 48kHz along the path (bits changed) and resampled to 211kHz in the DAC (bits changed), and then finally "room correction" has its way (bits changed again) with all those once perfect bits.
Do I worry about it?
No.
Y
yewneek
A good description of your own personal experiences. My gratitude for your valuable contribution in helping me explore in such a concise manner.
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
I don't think Plex has an equivalent to the button you can hit in Roon to see what's happening to your signal, but here's an example of how very non bit-perfect this stream is.
From there, it goes into my Denon receiver where it gets further mangled through it's room correction process before finally getting to my speakers, where the analog signal is digitized again!
Even with all that, it manages to sound pretty good.
Short answer, as Ray said...Don't worry about it too much beyond the curiosity level.
fuzzy_logic
TIA
Greg
The Plex client on windows can do bit-perfect. Plexamp for Windows doesn't have a setting for this - i think it's just IOS, Mac OS and Linux that do. I don't think Tidal played via Plex is bit-perfect though.
Y
yewneek
Ta! Plexamp on WIndows has bitperfect as a chargeable option. I'm looking into the rest!
Nutul
A setting for what?
fuzzy_logic
I think you are mistaken. There are no chargeable upgrades to Plexamp. You used to have to have Plex Pass, but now it is free for all Plex users.
