Audirvana vs Roon
  • Thread starter Deleted member 31750
  • Start date
D
Guest
Software for playback is becoming an essential part of the audio chain. Many claim that one sound better than the other and mostly that Audirvana has a better performance. I tried both and couldn’t tell the difference so I end up using Audirvana because the features are a better match to my needs. Which one you prefer and is there a way to put these two softwares to the test from measurements point of view?
VintageFlanker
Paris
Sure. As many say that silver cables sound better than copper ones.
Joke aside: When there are two challengers, audiophiles tend to always prefer the outsider. The other being seen as some mainstream thing for ignorant beginners. It happens that Roon is the most used overall (or at least more represented worldwide).
If it was the other way around, they would have called Roon sounding better. In reality: both sound 100% the same and if not, one is doing "bitperfect" very wrong. Then, usability, ecosystem, features are up to anyone to chose.
D
Guest
I see your point and I tend to agree but I am not 100% sure that are the same. Not better or worst but different? to me it didn’t make any dif in sound and was all down to features, UI etc. Will be very interesting so see some measurements.
D
Guest
D
Guest
I find that basing a discussion on the various subjective feelings of users not much use either....
We are not talking about subjective. We are talking about the possibility to put the softwares to the test with measurements. Listening is the other half of the process which is personal and equally important if not more important. Observation is the foundation of science
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
I use Roon, but not based on any expectation of better sound quality.
As long as the 'listening' part of the process has some needed controls. Too often, that's the part that's missing...completely.
D
Guest
Observation has no controls and the purpose is not to be provided as evidence but just as an observation. That’s part of science as a process
BDWoody
Chief Cat Herder
Moderator
If the observation is that one sounds better than the other, the controls would be needed to validate that. Most aren't interested in the actual validation of the observation. That's the difference between anecdote and evidence.
Raindog123
Melbourne, FL, USA
I just like Roon.
Yes it is somewhat expensive, but it glues together quite a few of my music-listening components across the house. Speaker systems in four different rooms and two headphone stations (and two apple TVs that in reality are never used for music). Qobuz, Tidal and my ripped CD collection. And a rather advanced DSP.
Personally, I do not have experience with Audirvana to compare (only read their reviews while deciding) but have extensive 4-year experience with Auralic's Lightning DS (aka LDS) ecosystem. Almost a year ago dropped the LDS in favor of Roon - mainly for Auralic (and iDevices for controls) HW exclusivity reason - and am very happy with my Roon choice.
Chrispy
PNW
This sounds fairly well based in subjectivity: "Many claim that one sound better than the other and mostly that Audirvana has a better performance". Or was this "performance" based on some thing solid to consider?
D
Guest
Totally agree. That’s my point. Will be interesting to take some measurements and see if these observations can be verified. Personally I tried both and couldn’t tell the difference
Reactions: CMB
zym1010
San Francisco Bay Area
AFAIK, Audirvana is bit perfect, modulus possible jitter. I did an experiment to verify it a while ago.
that being said, Audirvana now only offers a subscription-based product (Audirvana Studio) and has removed the old Audirvana 3.5 from their website. I will probably keep using the old 3.5 version until I have time to implement my own music library management software.
D
Guest
Do you have any results from your experiment?
zym1010
The result is shown in the URL. Basically a “recording” of Audirvana’s output using Audacity is exactly the same as the original files stores in 24/96, bit by bit.
Ata
Adelaide, Australia
I think it is safe to assume that, everything else being equal, Audirvana (3.5/Studio) and Roon offer the same SQ. Roon has much better UI and feature set, but comes at a premium price. Audirvana Studio tries to close the gap, but they are many releases away from catching up on stability, UI polish and features.
Jmudrick
My main complaint with Audirvana had been the mobile app blew up trying to load a large number of Qobuz favorites. This is now fixed in the Android app using Studio.
