You should upgrade or use an
alternative browser.
S
A new Amp is not the answer.
Look into better speakers, EQ, and equal loudness compensation.
S
The old "loudness" circuit on older equipment can go a long way in solving some of these issues...not a panacea, but it is often...
S
Does your amp have EQ or tone controls? From what I found online I don't think so, which seems strange... If it does, don't be...
S
Let's get back to basics. Adding more watts shouldn't change SQ significantly unless you are running your Audiolab into distortion, as...
S
That's about 4.5dB louder which is noticeable but not a huge difference. That's assuming you are using the full 50W and that you use...
S
Hi,
Probably a few things to think about before you just add more power. Your speakers are quite sensitive (easy to drive them loud so...
S
hi everybody,
currently i am using Audiolab 6000a ( 50 watts ) and Dali Oberon 5 speakers ( 150 watts )..
i am happy with this combo...
Loading…
Loading…
