Yes, a geothermal energy source would be a big bonus.
Like I've said before the oil and gas industry has all the trained and capable manpower to get into geothermal drilling, setting up the instrumentation and put in place satellite data up/down links for remote monitoring and drill hole management. There is a huge industry in the oil and gas operations and that goes from manufacturing heavy equipment such as drills (Which I have done.), manufacturing wheeled and tracked heavy duty service vehicles for remote operations (Which I have done.), manufacturing downhole tools (Which I have done.) and the analysis of the Earth strata for drill hole locations best suited for drilling. As well there are hundreds of thousands of out-of-service oil and gas drill holes and some of those are ready for geothermal energy extraction.
Geothermal energy is in my opinion a huge opportunity for the oil and gas industry.
Geothermal is actually up and running south of Clear Lake, Ca. There are some issues with it, in specific the the steam you get contains a mix of hard silicates (basically fine sand) and both H2S and sulfuric (and sulfurous) acids, which create a piping problem. Stainless avoids corrosion via sulfur compounds via a surface layer of hard sulfates and oxides, of course the silicates cheerfully chew right through that as fast as it's made. There is probably a solution (maybe ceramics) to this, one that would requires some scheduled replacements. In addition, the steam provided needs to be reinjected as water into the thermal area, or it will just dry up. (This has happened in a number of places throughout the west that have former geothermal power systems in place.)
It is something that could be solved, I do think, with some incentive to actually solve it instead of drilling for more oil. (note, fracking is part of the geothermal process, as well)
A very interesting place is the rift valley that contains the Salton Sea remains. The entire area is rife with hot springs and is otherwise "pretty much abandoned", and is active enough that geophysics people (my daughter is one) have to go there routinely to check the status of the railroad lines across the area for impending hot spring formation under the tracks. The area is surprisingly "hot" until one realizes (which I now do
) that the rift that constitutes the Gulf of California runs all the way up to the south end of the Sierras.
And, of course, there's the whole Long Valley/Mammoth Mountain area, but one might consider that part of the earth as "a touch too twitchy to fool with", perhaps. (It's an old caldera, and it is most certainly not a dead one.)
But, yes, using the planet's own nuclear power is an option, and there's a LOT of power down there.
https://earthquake.usgs.gov/earthqu....57206&range=week&magnitude=all&settings=true is the area around the Clear Lake geothermal area, by the way.
If you're curious, look at the town and place names on google maps right where I8 runs really close to the border in California.
