D
Deleted member 69358
Guest
My kid has a small room and am looking for speakers that have a small footprint and no need for speaker stands.
The speakers will be run from a Fosi amp about 40wpc and basically play vinyl from an Audio Technica turntable. She is not big into music so not even sure if it is worth doing. I would like to at least introduce her to something a bit better than her kiddie LG Shelf system.
Contenders, looking for under $200
Magnat Monitor Supreme 1002 - $99 each
Jamo S 809 (comes with center channel not needed.) - $219 pair
Dayton Audio T652 - $149 pair
Monolith by Monoprice Audition T4 - $99 each
Specs on the Magnat Monitor Supreme 1002 look best, down to 19hz and 92db sensitivity but I have never heard of these.
Jamos seem to be hit or miss
Dayton Audio and Monolith do not seem to go much below 50hz and are low sensitivity.
OTOH, a pair of Dayton Audio B652 is only $49 but only go down to 70hz and have 87db sensitivity and maybe I can build a set of speaker stands. The Daytons seem to be no better than the Infinity satellites from, my old HTIB set.
For used, I have a seller locally with a pair of Bose 201 IV @ $65 and a set of Infinity Reference 2000.1 @ $50
What should I do?
What should I do?
