Updated my Metric Halo ULN2 and LIO8 from 2d to 3d spec, now to learn the new software...
I took on a job many moons ago making 2000 RCA interconnects using MIT product. Got real good at it real fastI had to make some cables up for the new Gradients, no soldering involved I was still pitiful, a chimpanzee would have been quicker and made a better job of it.
This is not in my bank. That is not my bank. Nor is it my flat, but this video catches my attention for many many reasons.No Pavel, the rules are clear, the topic is "what is on your workbench right now". No off topic posts please, and that includes the floor, lounge-room carpet or kitchen table etc.
A 32 Gb/s SerDes test chip...
Good advice, thanks. I gave it a shot today, the display has improved and is almost readable. It's better than it was, but it's still not easy to read. I'll continue to wait for the replacement. The bad news is that I sliced my thumb open on the edge of the glass and didn't even know it until a drop appeared on the display. Wiping off the drop just made a big smear until I looked at my thumb to see the gaping slice.A hot air rework unit can sometimes resurrect the ribbon-to-glass contacts and give you a working LCD. I've had a decent success over the years.
For what?
Measuring influence of speaker cable to amplitude response.
Blue - at amp output terminals
Brown - behind speaker cable, 6m of 2x4mm2 zip cord, at speaker terminals
Audible or not?
That makes a fantastic case for exotic kilobuck cables... I mean, it totally makes sense... you buy the amp for the 77.8dB and spend another similar amount for that last 0.1-0.2dB. Without that, why even bother listening at all! Wait, don't tell me those exotic cables do the same thing?!?!?
I totally agree that talking about cable price is pointless - which was my point. Obviously cheap cables come in all the same gauges as expensive ones. So a 6m length of ~17ga wire vs ~11ga wire? Yeah, I would expect an obvious measurable difference between the two... as far as actually hearing that deviation (even when it's slightly higher than that for much of the lower-mid range...) of that, I'm less convinced.Regardless your ironic tone, the result will simply and only depend on cable impedance, R + jwL, which makes the divider with the speaker impedance. The smaller R and L, the smaller effect to amplitude response. I can make you sure that with the length mentioned, 6m, 2 x 1mm2 will be audibly different from 2 x 4mm2 zip cord. Talking about cable price is pointless.
The effect of cable impedance can be quite easily measured and simulated, so if you can do one or both, you can try. "77.8" number is pointless, it was just there because of SPL calibration. dB is always dB, 0.2dB field was the result.
Audio Buddy's Audio Cat applied some Audio Cat Piss to his AC power filter thingy.
It opened its PCB mount IEC inlet internally, between the spade and pin.
Zo = sqrt[ (R+jwL) / (G + jwC) ] to first order -- capacitance can be important too.
