- Thread Starter
- #141
It rather depends - USB has two speeds in relation to DACs, 'full' and 'high'. Doing isolation for full speed USB is cheap and simple. For high speed, not at all simple. High speed is needed for above 96kHz sample rates.
It is hard to find poor design a lot of high-end gear because by definition they have ample money to throw at the problem. They can still screw things up but the main reason that happens, i.e. keep the cost to the minimum, makes it harder. This is with respect to electronics. I think in speakers there is a lot more opportunity to mess things up.A question primarily to Sonny but everyone please feel free to chip in.
Do you often see what you would consider poor design in audio equipment?
What would you consider poor design, would omitting galvanic isolation from a USB DAC be poor practise?
Keith.
I thought I posted this recently, but maybe not:Incompetent digital was the CD from the 80s, and till roughly the mid 90s. ...Sounded real real bad...no life...dysfunctional...disconnected...disjointed.
I agree and have a couple of the early CDs you mention. I have no big issues with the sound of most early CDs and found their sound has improved over the years along with a few upgrades in my CD player/DAC. Today when buying older music off ebay I will choose a CD from 80-90s era over a later master unless it is something special like a Wilson/Hoffman remaster. As a general rule I find the not highly compressed older releases to sound superior.I thought I posted this recently, but maybe not:
Early Digital
Even the earliest A/D/A devices had very high fidelity, better than any analog tape deck, and vastly better than any LP. Any problems with "brittle" or "harsh" sound etc on early CDs were likely due to using the wrong master tapes.
--Ethan
I had a lot of CDs from the mid-later 80s and still buy a few today. Never ran into any the developed issues due to age and to hear the talk from years back they were all going do die from CD rot. I've yet to run into a single case.My accent was mainly on the recordings, yes Ethan. The software (Compact Disc) was manufactured with several defects; pinholes, discoloration, melting of the label layer (most important surface), ...brief the CD was an inferior medium badly produced.
I tried to de-emphasize the "incompetently realized" but I failed.
The Opp0 BDP-105 BR player cost $999-1,099 (MSRP). ModWright optimize it with tubes (premium), and a separate power supply, do some surgical work inside.
Roughly $4,000 later it sounds marvelous...competing with $10,000-30,000 players.
Did Oppo "incompetently" missed the digital reaping benefits? No, they competently delivered a product @ a price point.
That's why it was a question I was asking.
He is saying he measured the output and didn't see a change in distortion. Without measurements and/or bias controlled test, we don't know if his observation is valid. Heck, I would take even scope output of the power supply rails showing a difference. Without any confirmation it is hard to put value on the changes he has made.About three days ago I posted up this link : http://www.diyaudio.com/forums/digital-line-level/288078-bricasti-m1-processor-modification.html and invited questions. None so far have been forthcoming (coyness? don't say its so!) so I'll point out a couple of things I noticed from this, as the thread's about 'digital incompetence'.
Firstly incompetence isn't all-or-nothing, even when its digital. Its a matter of degree - clearly the Bricasti M1 ticks a lot of boxes in terms of sounding relatively decent and also highly respectable measurements.
Yet the designers still missed something - the treble quality as reported by Art V in that post. What was responsible for the sub-par HF? My hypothesis is that it was excessive power supply noise on the AD843 I/V converter rails.
Ethan recently deployed the phrase 'competent digital is audibly transparent' so what are members ideas on how to spot incompetent (i.e. not transparent) digital? Does incompetent digital have any defining traits?
I'll kick off by pointing out a couple of things I see as incompetent in much digital. Firstly S-D DACs which introduce noise modulation when fed with high crest factor (i.e. music-like) signals. Secondly digital filters (known as half-band) which violate the Nyquist criteria by only being -6dB at that frequency. Hence introduce imaging/aliasing artifacts.
Any others?
Miserable tiny power supply. The transformer is the size of cubic squared quarter....you know...with that plastic yellow strip.
