Mivera
One of the things I've found which makes an improvement to the SQ of DACs using that chip (TDA1543) is working around the limitations of its internal biassing current source. This is something that at least one other designer found independently too. The chip hasn't sufficient power supply rejection with that CCS in circuit. Fortunately on that device its a simple matter to turn it off and build an external one to do the same job. Cost in BOM terms is single digit cents.
Don't ever tell a seasoned, golden eared, cream of the crop audiophile that a 15 cent part could have a bigger impact than a $5000 set of cables. One thing I have learn't from audiophiles on forums is, it only matters if it's on the outside of the box. Once you cross the barrier of the binding posts/power inlet, analog/digital connectors, it doesn't matter anymore.
