dallasjustice
Convolution
https://kb.roonlabs.com/DSP_Engine:_Convolution
Arguments are for convincing other people. The good news is you only need to convince yourself. You can try it for free.Question from a non-Roon user: what's the best argument for using Roon? Currently streaming tidal and local files through sonos connect and the sonos interface.
A few things for me:Question from a non-Roon user: what's the best argument for using Roon? Currently streaming tidal and local files through sonos connect and the sonos interface.
You are being highly ethical in providing that caution. Here is a recent thread in another forum that I added some comments to:You are welcome but be forewarned that most classical lovers don't like Roon. I think their comments are in my thread above. Get a trial version and see if it fits your needs.
http://www.audioasylum.com/forums/pcaudio/messages/16/162901.html
I suspect Roon can be made to work for a small classical library. But, not a large one.
People keep saying Roon is working on classical. Classical really just needs a few more standard tag fields than pop music albums do. The problem is that the raw metadata provided by disc authors and databases is rather messy and inconsistent from disc to disc. So, unless Roon or someone invests massively in data cleanup, the results will be poor at the user end. And, given classical's small market share, is that massive effort worth it? BTW, essentially the same problem exists with searching Tidal for classical.
Bottom line. In my opinion, maintaining a large classical library will never be smooth sailing via automatic Roon tagging. You will always have to edit or amend the standard tags provided with the disc or download in classical. So, I do not find Roon the best choice for me for classical. JRiver is, at least for now.
Ah, thats a bummer in that case. Guess I just need to give it a try.
Thanks. I prefer google over the dewey system.
Question: How does Roon organize classical albums from within Tidal? I came rather late to the classical party, so most of my classical listening is via Tidal (while I have lots of jazz, rock and electronica that is ripped from CDs). Does Roon do a better job than the native Tidal app when it comes to searching for streamed classical music?
I think the underlying causes are the same - lack of sufficient and consistent metadata for each and every album. That likely goes deeper into the issue that the whole metadata scheme - the standard tag fields - used in the recording industry are rock/pop, meaning not classically, oriented. Hence, there are gazillions of albums already out there that do not have sufficient, well organized data to be useful today.
I am not an expert on either Roon or Tidal separately or together, but I have considered both a little. So, I cannot answer your question adequately.
All that I was trying to say was that Tidal searches for classical music are inadequate, as they are with Roon. I think the underlying causes are the same - lack of sufficient and consistent metadata for each and every album. That likely goes deeper into the issue that the whole metadata scheme - the standard tag fields - used in the recording industry are rock/pop, meaning not classically, oriented. Hence, there are gazillions of albums already out there that do not have sufficient, well organized data to be useful today.
I recognize that most classical music lovers don't like Roon.
However, about 50% of listening is classical and I find it fine. More than fine. I prefer it.
My suspicion is that people who use a tree-based approach, with carefully named directories and file names, may find Roon frustrating because it doesn't care about directory structures or file names or where music resides.
Me, personally, I think that's one of it's strong points -- I like the fact that location is obscured.
However, if meta-tagging is bad, missing, or incomplete, and one isn't comfortable using a search based approach, as opposed to browsing a tree, it would be annoying.
It find it analogous to finding information via Dewey Decimal System vs Google.
