REW 10-Band PEQ
Zorlac
Spokane, WA
I used REW this weekend to measure my room and create a PEQ file. I noticed that REW generated 16-bands. How can I limit this to only 10-bands? Some of the new DACs coming out (e.g., Topping) will have a built-in 10-band PEQ function. Just trying to educate myself now since I really like the idea of having PEQ within the DAC itself.
Z
Zorlac
Spokane, WA
Oh, okay. I guess I was thinking that the EQs only showed after running the correction algorithm. So untick 6 of 16 and then run the correction algorithm to generate the generic PEQ file?
Rednaxela
NL
I believe REW has 20 slots of which it apparently used 16 in your case. If you want to limit this to 10, you’d have to disable 10 filters.
