How to convert the EQ from Sonarworks SoundID to 10 Band PEQ?
Zwuckel
Hi,
I have some setting in the demo of SoundID. Sound ID compensates my headphones to the flat level and then my aproximated Harman curve. I bought the Quedlix 5k which has a 10 band PEQ. I tried to replicate the setting with no success. Sometimes the bands are cancelling each other out. E.g. I tried with a 3000 peak with 6db and a low shelf at 4k with -9 db, but it´s effecting the 3k band. Is there a tutorial or something? Unfortunately the headphones have no AutoEQ setting and I couldn´t find settings in the web.
Thanks, Sebastian
Rednaxela
NL
If there is a way to transfer your curves to REW you should be able to use its EQ module for this.
staticV3
Use Room EQ Wizard and Audacity to measure the filter response of your current SoundID settings, then export the response as .CSV, import it into autoeq.app, and let it create a Qudelix 5K preset for you.
Here's an example of how to use REW and Audacity to measure a filter:
staticV3
BTW, SoundID SR is already basically Harman, so applying a "Harman" correction on top of that will surely screw things up. Would not recommend.
