Noise shaped CDs
MCH
Question, just for my own curiosity:
Modern DAC ICs still come with de-emphasis filters that can be activated via registers, but i don't see the DACs usually discussed here have the option to activate such filters. Is it because they are activated automatically? (i see this is a possibility with spdif signals)
I also see DAC ICs that have filters for sample rates other than 44.1 kHz (i.e. 32 or 48 kHz). Was emphasis used in other commercial formats?
DonH56
Monument, CO
The emphasis bit is (or should be) on the CD itself at the start of the track. The player reads that bit (among others, see "CD Q code" or something like that) and uses that information to program the emphasis. It is part of the CD standard.
Blumlein 88
BTW, lest you think I'm just picking on this recording, the most recent recording I have of this concerto is from 2019 and I'd be shocked if it was recorded at less than 24-bit. It's louder than the older BIS recording (-33dB for the first movement) and ambient noise from the venue is more clearly audible, but the hiss is also still clearly audible in the quiet cadenzas. Why is this still a problem on a CD released in the last few years?
Other than total electronic creations, I'm not sure there is a recording with noise less than about -70 dbFS. As already said by Ifrit, mics, electronics and room noise all add up.
darmok
darmok
Unlikely the noise you hear is quantization, most likely digitized analog noise.
Sigh. Are you telling me that I won't hear the dithering noise in this?
Even without the dither the quantization noise is very clearly audible. This is the exact same output level I was using for my listening tests earlier. Generating this in a higher bit depth and then using Audacity to apply noise-shaped dither to 16-bit results in much less audible hiss and at a higher frequency.
Now there very well might be other sources of noise in these recordings, but here's what a 15-second excerpt of the 2019 recording looks like:
Hmmm......
I guess it must be analog noise in the REW generator that's creating the exact same noise floor as this CD. :facepalm:
darmok
darmok
Room noise doesn't sound like hiss. It sounds like room noise, and the difference in spectral character is very apparent.
Recording of a different concerto from a SACD rip overlaid on the previous one. Note that by 10KHz the noise floor is down by 12dB, or 9dB A-weighted. And yes, before someone calls me on it, I applied 6dB of gain to the SACD rip before loading this excerpt into REW, which left about 0.5dB of headroom on the whole concerto.
If the point of a recording of live music is to recreate the experience of being there, then room noise is a part of that. Hiss, whatever the source, is not.
Ifrit
What a wide a deep field of electronics development you have in front of you, but you might just be the one that creates piece of electronics that doesn't produce noise in form of a hiss.
darmok
darmok
What was the point of this comment?
On multitone? unlikely.
Did you try it yourself? Pay attention to the parameters...
Ifrit
To reinforce my previous one.
No. I did, however, try many different noise shaping algorithms during production of the CD/HiRes files, including cello concertos. A lot of people here would argue that the type of noise shaping and presence of dither at all is not audible on acoustic instruments recordings. I have a first hand experience about noise induced by electronics and not being affected by dither types (to my imperfect ears, of course), therefore I am skeptical.
Multitone signal still is not real musical material, and is hardly representative in this matter.
darmok
darmok
No.
"Whereof one cannot speak, thereof one must be silent."
I'm showing example excerpts from a real, commercially released recording (Eckart Runge cello, "Transitions", Capriccio C5362, 2019, track 5, 15 seconds starting at 0m10s). The intercept point between the spectrum of that segment of recording and the 16-bit TPDF dithered noise floor is at 3KHz. If I'm hearing anything at all above 3KHz, that's what it's from. So what happens if I low-pass this excerpt at 3KHz (48dB/octave)?
Hey, guess what? No hiss! Of course, I had to actually go through all the effort of putting a pair of headphones on my ears to try it. Wouldn't expect anyone else to go through all that trouble.
Just for fun I switched out the closed-back headphone (Elegia) for a semi-open (Emotiva GR-1) that's sensitive enough to reveal the noise floor of my amp at full gain. I'm sitting in a treated room but the heat is on and there's plenty of electronics with fans going in here. Same result.
I am skeptical.
No, you're cynical. A skeptic is willing to actually try the experiment if the procedure is documented.
Blumlein 88
Well, for the record, I always use shaped-noise dithering when mastering to 16 bits for clients.
Yeah, I did one CD, which was from material I recorded at 96/24. I used noise shaped dither during resampling to 44/16, and told the guys making the CD not to redither it. Yeah, like they listened to me............not. Redithered it with some lousy dither in an old DAW. Was their "standard" practice. :mad:
