Hmm, is that something MSB, Benchmark or dCS would do?
I'm 18000kms from home and don't have access to a Tidal desktop client, or Roon, so I can't have a play.
It is DRM in not so good a disguise.Initially I was very sceptic vs MQA since it seemed as a DRM in disguise
Now that Tidal is opening the MQA streams, the non-MQA CD rate stream are gone.
So you pay $ into the MQA monster to get the hirez stream or you listen to the un-decoded lossy stream.
If they have there way and MQA becomes the defacto standard they will have cut us off of true CD quality sound unless you buy into the MQA taxes in some manner.
I call the DRM
Even all of that might actually be forgivable if it actually represented a significant leap forward in quality on par with what we got when CD first came out.
But it isn't. Sounds like regular, good quality lossless 16bit PCM.
s I understand it, MQA software decoders, such as utilized by Tidal, cannot implement the MQA playback interpolation filter. That would require reprogramming of the interpolation filter within the DAC. Which would then mean that Tidal MQA only enables part of the sound character intended to be delivered by MQA.
Is it not just limited to 24/96 via software decoding ?
If so who cares ??
Not fussed.. Listening to kyuss right now so nothing else mattersYou should care because of potential impact on the entire business model of the music industry / music streamers, even if high resolution content is of no interest to you.
Here is what one of the producers for Linn records had to say about his concerns about MQA leading to vendor lock-in:
"MQA is Bad for Music"
Nah, the vivids chomp through that OK.. Even at high SPL..I hope you got those Cerwin Vegas.
If what you said about software decoders lacking the interpolation filter is correct, saying it "only enables part of the sound" is a huge understatement. Without the ability to use the other half of the unfolding, the discarded data will not be restored at playback.
I'd expect if it's a predictable issue it can be compensated for..The missing part I was referring to does not discard any data. It's simply the playback interpolation filter response. MQA ideally utilizes an specific non-ringing filter function for both anti-alias at recording/remastering, and anti-image at playback. The recording/remastering end of the system chain can be controlled by the production company to utilize the specified filter, but that is not the case at the playback end. Most non-MQA DACs have one or a few filter functions programmed in them, which are most often fixed and not reprogrammable.
What should move an non-MQA DAC closer to the sound of fully decoded MQA, however, is to select the non-MQA DAC's soft slope digital filter option (if it has one) when playing software decoded MQA streams, such as via Tidal.
