watchnerd
I'm beefing up my audio testing gear so that I can better calibrate my reel-to-reel tape decks and have a new oscilloscope and function generator. I might use the gear for TT alignment or other experiments (e.g. SUT measuring), as well.
What I'm missing is a really good millivolt meter suitable for audio.
My current multimeter is a Fluke 107, which seems reasonably accurate in the whole 1+ volt range, but I don't seem to get consistent numbers when dealing with .12 - .4 mV level signals, probably due to lack of true RMS capabilities.
Is there something better, more suitable for audio?
Or is the Fluke 107 good enough?
Budget up to $300-$400 would be fine.
Edit , added from @NTK
New table with 10 KHz, 10 Hz and 50 kHz accuracies. Note that only the 6.5 digit Siglent is rated to 10 Hz. The other ones are start at 20 Hz, except Keysight starts at 45 Hz. I kept the calculated numbers and change them to red. They are NOT accurate but represent the accuracies when the signal frequency enters the frequency bandwidth range.
