KEF R3 vs Revel M106
just1n
Community,
If someone were looking to upgrade speakers at this price point, which would you choose?
Seems to be a win-win situation, but is there a compelling reason to choose one over the other? They both measure well with the only notable differences being the upper-mid/high emphasis and impedance dip to below 3ohm on the R3.
J
just1n
I could add that if expanding to surround sound in the future, the Revel C208 is nearly twice the price of the KEF R2c, but there is no smaller bookshelf in the KEF R line.
J
just1n
You are correct. I have read and interpreted the reviews’ data to the best of my ability, but the threads tend to get a little sidetracked. Unfortunately I do not have the chance to listen to either let alone both side by side.
The room is 13’l x 10’w x 9.5’h, with the speaker along the short wall. Not a large living room, and the speakers will have to be close to the wall.
J
just1n
Yes, I saw the sale which is motivating this purchase, but there is also a demo pair of M106 for a very similar price.
sweetchaos
The Curator
BC, Canada
Then it depends on whether you like wider dispersion (M106) or narrower dispersion (R3).
Also, Kef appears to have better distortion handling at 96db:
vs Revel:
Plus R3 has better vertical directivity than M106, if that matters to you.
J
just1n
vs Revel:
Thank you for the response. With dispersion I’m not sure I understand the implications. Would that mean there is more chance of a “sweet spot” as dispersion narrows? Could you explain the pros/cons or direct me to an explainer? If it’s
sweetchaos
The Curator
BC, Canada
It’s a personal preference.
Plus, discussion on:
J
just1n
The reading does make the topic seem either too complicated or too opinionated. I’ll give the video a watch. Appreciate the responses thus far everyone.
Freeway
I know we should not be subjective around, but have you read amirm's subjective review of R3 vs M16 in the R3 review? That will mess you right up.
There is the Performa C205 at half the price of the C208.
BrokenEnglishGuy
Do you mean the subjective review that amir updated because he listened wrong the R3 without any room correction?
Freeway
Do you mean the subjective review that amir update because he listened wrong the R3 without any room correction?
Now my mind has been messed right up.
Room mode @105 hz, filter, new protocol, Olive's latest tests and the case of the mysterious second (untested??) speaker.
So much for subjective reviews. I know better.
My bias for the Revel M105s I am listening to right now made me do it.
J
just1n
What a rabbit hole. Finished the R3 thread and will tackle the M106 next. This dispersion topic is pretty unclear, too. Live vs studio recordings. Orchestral vs pop. Voice intelligibility. Dizzying.
richard12511
