Kali LP6 2nd wave measurements.
PeterNL
Netherlands
Hello, after buying monitor stands (isoAcoustics ISO-200), finally I could set up my Kali LP6 second wave on my ear level. I did also a new measurements using Umik-1 and REW. Room is totally untreated, it is just another room to listen and enjoy the music.
In my other setup I'm using Dirac correction (Wharfedale Linton, Audiophonics Ncore and Dirac PC), so I'am not able to use Dirac in these setup simultaneously (only one license).
I am going to use PEQ (APO equalizer) or something similar. Finding a good target curve will be a long journey.
Here are the measurements:
PeterNL
PeterNL
Netherlands
You should really reduce window size for improved accuracy. I have used sub-1 ms for the treble. Piecing together an EQ by frequency range is arguably annoying but I don't see a better way of doing it. MMM or at least averaging multiple measurements is highly recommended as well.
I have also MMM measurements :) and Kali dB Average and RMS Average is "Average" :)
PeterNL
PeterNL
Netherlands
My main speakers room curve and EQ looks like that and I like it very much:
