Is baffle shape really important? What about these ideas?
sarumbear
I will rephrase my question and I am not trying to be confrontational.
Are in-wall speakers inherently better than enclosed boxes even with same back box.
It depends on what you want to achieve. Sound emitted in a 2pi and 4pi space propagates differently. I don’t think they are directly comparable.
fpitas
Northern Virginia, USA
I think you meant to say, "Yes, as long as the crossover is redesigned to remove any baffle step compensation present."
Correct. Although generally the designer knows the application. Certainly, true for in-wall studio monitors. I guess somebody might get creative at home with normal speakers.
Reactions: JPA
sarumbear
Timcognito
NorCal
Thanks all, found this, it may help the uninitiated:
Did not intend to hijack the thread
fpitas
sarumbear
I assume Genelec has the means to adjust baffle step.
8341A flush mounting box is designed to avoid reflection from the wall behind the speaker. Benefits are the lack of cancellation dips caused by rear wall reflection and increased bass level due to the 2 pi radiation space. The increase in bass level can be compensated by GLM without changing the increased SPL capability.
fpitas
617
Somerville, MA
In theory, yes, practically, no, only because most in-wall speakers available for sale aren't that great, but if I was designing a listening room from scratch I would absolutely start with baffle mounted speakers
Timcognito
NorCal
What are the common flaws? I would guess that the room size and geometry would be the biggest impediment, no?
fpitas
Sarumbear just showed us a Genelec, but it's true most people don't think of in-wall for their homes. With DIY it would be as easy as otherwise.
fpitas
I think most people don't want the back of speakers hanging into the next room.
sarumbear
Timcognito
NorCal
Are saying need for back box is the issue?
fpitas
Timcognito
NorCal
Sure. How do you make a speaker only what, maybe 5" deep without screwing it up?
Wouldn't that apply only to LF drivers that are supposedly nondirectional .
fpitas
That's true, but I'm not sure what you mean. How do you keep the woofer back wave from reflecting from the back wall of the cabinet and going out the cone?
Timcognito
NorCal
I meant that the sub has more placement options, so in-walls with a sub. 16" spaced studs allow for a large short throw surface also.
fpitas
How do you get the requisite box volume? Unless you mean the infinite baffle drivers with 0.707 Qts. That is sometimes done, but you need a convenient room behind them.
