From a technical perspective, reclockers make no sense if you connect your pi to a async DAC through USB. Fancy, but nah.All this re-clockers, low-jitter transports are completely new things for me, and they are not cheap.
Any thoughts on this - is this worth it, and with what equipment, or is it just better to buy some existing streamers?
With piCorePlayer yes, at least in my experience. It's less certain with other distros - issue #2215 was closed as wontfix so is presumably still a potential problem if you happen to have the wrong combination of factors. If you've already got an older Pi you may as well give it a go and see, but if buying new a 4 would be a safer bet. I haven't heard any complaints about dropouts with the 5 either, but it hasn't seen so much use yet.Pi 3 or 4 can do this easily. I also had it set up at one time with a Pi 0 and it worked fine.
So, Rpi5 and DX3 Pro+ over USB should be enough for solid streaming, and all this stuff is basically just a bling worse than a thousand dollar RCA cable?In my opinion, all that Ian Canada stuff, while undoubtably clever, is trying to solve problems that don't really exist.
Async USB out from a PI4 or 5 into a well engineered DAC will be technically perfect, why worry about anything else ?
yeh.So, Rpi5 and DX3 Pro+ over USB should be enough for solid streaming, and all this stuff is basically just a bling worse than a thousand dollar RCA cable?
It didn't change until the 4. It was a 3 I was using to replicate issue #2215.Pi 3 and beyond sorted the usb interface
A version 5 is massive overkill unless you are doing very significant DSP. Even a pi 4 is is overspec'd. Moode audio will run on. Pi zero 2w with Camilladsp doing parametric eq and still doesn't run over 10% cpu usage. If I didn't need an ethernet connector I'd save some money and use a pi zero 2w.So, Rpi5 and DX3 Pro+ over USB should be enough for solid streaming, and all this stuff is basically just a bling worse than a thousand dollar RCA cable?
Reading that,I’m actually unsure of why I brought a Wiim pro,probably better off connecting my iPad through usb to my Rme,funniest thing is I’d never even thought of itFor some evidence of how little difference the streamer device makes to the analog output of a decent USB DAC see for example https://archimago.blogspot.com/2023/12/do-bit-perfect-digital-sources-affect.html
And if you are happy without camilladsp (ie you only need peak-only peq) you can get by using the original pi zero w.A version 5 is massive overkill unless you are doing very significant DSP. Even a pi 4 is is overspec'd. Moode audio will run on. Pi zero 2w with Camilladsp doing parametric eq and still doesn't run over 10% cpu usage. If I didn't need an ethernet connector I'd save some money and use a pi zero 2w.
Not familiar with "issue #2215". i may have been thinking of archimago's blog regarding the pi 3 usb capability, but am happy to be better informed.It didn't change until the 4. It was a 3 I was using to replicate issue #2215.
Random pops and clicks with USB audio that may be more or less frequent, or not happen at all, depending on factors including workload. Often blamed on having the network port sharing the USB, but that's just one factor that affects it rather than the cause. Note that similar things can happen on Windows too when something causes interrupt latency to increase.Not familiar with "issue #2215". i may have been thinking of archimago's blog regarding the pi 3 usb capability, but am happy to be better informed.
