I guess I'm getting a bit tired of hearing about magical analog sound!
Why? I'm pretty happy if it's not making any weird noises because of equipment. 99% of the noise from most analog sources is not
because of the source but the lack of adequate noise reduction from the actual playback gear. Reel to Reels start at the heads and
records start at the stylus and go DOWN from there not UP. Normally the source isn't the weak spot.
That's where most people take a stand on quality when it's the actual gear. I also use "The Parks Puffin" in some applications for recording.
Top notch affordable playback isn't just a few buck no different than a RtR. There is a point of diminishing that for me is about 1K for a cart
1-3k for a great analog phono preamp and making sure you have the correct cables and loading if you need to load the cart. My Parks
and Cocktail X40 (45?) are excellent tools for recording and dealing with considerable issues from some source material.
ABX? phooy. I let the Pros do that, I just make sure they are a trusted source. ASR is pretty tried and true for scrutiny and access to data that
backs it up. It's open ended for the most part. Nothing is written in stone from an objective point of view except proven facts.
Analog just like digital is only as good as the ROOM not the source. The source is XX%, the gear is XX%, the grid is XX%, the speakers are XX%
and the Room acoustics is the other 50%. Your money is better spent on the room, if your looking to improve the sound quality.
If you're looking for a magic BEAN they are all gone after the Jack in the beanstalk incident.
I'll admit this, I love to play records on my old Thoren 124s and Russco Broadcast. 10-20 records and you're set, with just a few rules to follow
for the rest of your life mainly about record hygiene and how to do it.
Here is a question. At the CD output RCA/XLRs is the signal analog or digital? When the signal from Spotify comes out of the back of most
preamps to go to power amps or analog active crossovers, is that a digital or an analog signal? I have Sony SACD that are about as good as
it gets and they are 30+ years old. I can adjust to my ears desire but none of it will fix an untreated room with even worse placement and
the use of existing furniture, curtains and seated position that will help with the SQ. In one ear and out the other with quite a few DSP junkies.
A C20/MC240/D300 Jensen Imperials (OLD GEAR) with a router from the cable company providing the Music Channel as a source is putting out a
Analog is a lot more magic than you might think, maybe?
Regards
