Different cables, different measurements?
pogo
I think we have several effects playing in here. Where are your room modes, for example?
solderdude
The Neitherlands
yeah, this is why i share 2 videos
It shows the measurement method is wrong.
There is no question you hear differences but the measurements only seem to confirm your suspicions.
10dB narrow band differences cannot possibly come from cables, not even EQ is that narrow band anyway.
GaryY
For example, I see that curtain shows different light slot through the windows in 2 measurements.
GaryY
Without exaggeration, I repect this kind of curiousity. But really expensive cables for GHz measurement show only 0.? or 0.0?dB variation DUT by DUT. If copper and aluminum could result in 10dB difference in kHz range, I think world could be really chaos.
D
Deleted member 48726
Guest
Ahh! -This is the explanation for why the world is indeed chaotic.
D
Deleted member 21219
Guest
'Cause and effect, chain of events
All of the chaos makes perfect sense
When you're spinnin' round
Things come undone
Welcome to Earth, third rock from the Sun
... courtesy Joe Diffie.
D
Guest
Oh boy do we solve much grander things than HiFi issues on this forum! :cool:
antcollinet
UK/Cheshire
For example, I see that curtain shows different light slot through the windows in 2 measurements.View attachment 343301View attachment 343302
Plus we don't know how accurately the operator is placed in exactly the same position for each measurement. I very much doubt he could get that very precise after moving to change the cables over.
