DavyRockstar
- Joined
- Feb 15, 2023
- Messages
- 23
- Likes
- 2
So, I finally have a proof?? I finally have the ultimate answer to the ultimate question?? (Go to bold for the resume)
Hi, everyone, since I'm an engineer i don't really believed how a cable might affect sound, i mean, YES there are all types of cables and some are for specific tasks, such as the Lizt cable which is a type of cable done with the specific task to transmit very high radio frequencies, since regular cable starts to roll off at 50KHz.... and shielded cable, highly used in electronics.... but this is far different to change how a sound signal passes thru whith an objective change.
Sure, test like impedance, capacitance, and inductance are important but most of the time this test does not show if a cable can truly modify a signal that passes thru it.
I was improving my system, I love my pioneer CS-A700, and i did some upgrades with better quality capacitors, cleaning the pots, filling the boxes with glass fiber... you need to make a good pair with the correct amplifier to achieve a good sound thoe, which I don't have, I use a Nakamichi amplifier 1, a very refine unit, but the classic lean in bass Japanese sound, and as my source I use a Pro-Ject Pre Box S2 Digital and my computer... using DSP equalizers makes the bass sound the way it should.... just the midrange was a little harsh at mid-high volumes... at this time I used a good quality aluminum cable from a car audio brand (don't remember which) it was copper plated
But I always wandered, how people could be so naive to waste a lot of money in cables if they do not do any improvement?
So, I decided to put my butt to work and do a little research in cable technology.... I used this Gotham cable
With 24 multipair 24AWG cables... so I used 12pair for each channel, virgin copper and really great specs... and well you can see the photos... I end up doing something similar to a Lizt cable, but each conductor being a cable and not a single wire, it is also passively shielded....
I do my test with RTA using a BLUE microphone... I know, I know; it is not a microphone manufactured for this purpose and it may have some strange anomalies in the measurements, but I just wanted to see myself if there was a change, also the mic is good enough for this,
- These results are RAW without any kind of processing or filters....
- I've done each test multiple times to confirm the results using pink noise (the results were exactly the same every time)
- The tests were done using the exact same parameters in all variables
- Since this is not a pro Mic, it is hard to know the real SPL volume in dB, but i think, it is not really meaningful for the test
the test 1 and video 1 shows the measurements and the sound of my Gotham custom cable.... and as you can compare, is very different in bass and in the mid high section (1000 to 5000Hz) responding flatter in that particular section.... the bass sounds somehow "more solid"... you could say that it was better with aluminum because that crest at 40Hz but it was like it bounce way more, with copper sounds faster more articulated, hard to explain I’m not an “audiophile”... and it is easy to confirm the sound differences in the song, when the organ hits, specially. You cannot hear how harsh the organ sounds using aluminum (as you can see the Gain knob of the mic is set low so I was playing kinda high volume...), using frequency generator also confirms how harsh those frequencies sound with aluminum (test not shown)
Lastly, I could get a pair of prosound cable, very good quality pure copper cable and very affordable... i done the test again and well there were differences between them, this time they were so minimum that I can confirm that the frequency response I get was practically the same..... as for the sound, well maybe the fact that I’ve inverted a lot of time doing the Gotham cable, but I think it just sounds smoother and again the bass feels better articulated but it might be a placebo effect, who knows (in this case I could not tell the difference between on cable and the other in a blind test)... as for me, my CS-A700 sounds 10% better, in my opinion using the Gotham cable vs the aluminum one (and I can tell the difference in a blind test, NO MORE HARSHNESS), and 3% better vs the prosound this is just subjective, of course
TEST 1 copper, the graphic in RED show the frequency response
Video 1 copper
TEST 2 Aluminum
Video 2 aluminum
Video 1 copper
Google Photos
photos.google.com
TEST 2 Aluminum
Video 2 aluminum
Google Photos
photos.google.com
