They artistically draw clipped rail-to-rail waveforms on your 'scope, for sure. Some Valium could help that amplifier.Very creative, if you're not careful.
If the Mills and Hawksford paper are posted anywhere, they cover the subject very nicely. There was also a book on the subject by a Finnish guy whose name escapes me.Some light reading on these topics.
Perhaps one complicating factor is that recent drivers of any quality tend to have shorting rings to minimize the inductance. Once upon a time that inductance variation may have tipped the performance in the favor of current drive.If the Mills and Hawksford paper are posted anywhere, they cover the subject very nicely. There was also a book on the subject by a Finnish guy whose name escapes me.
Under some circumstances, they showed a small reduction in distortion with current drive of some special drivers, though it's difficult to actually get any significant advantage in the real world.
Edit: Mills and Hawksford
Esa Meriläinen: https://www.current-drive.info/There was also a book on the subject by a Finnish guy whose name escapes me.
The current amplifier only eliminates the current error. However, a loudspeaker is a much more complicated thing. Mechanics continue to be the main source of distortion.a small reduction in distortion with current drive
So stop wasting time tilting at this windmill and go after something useful.Mechanics continue to be the main source of distortion.
What does "almost unlimited slope" mean? Current is no different than voltage in needing at least N reactive elements for an a N-order filter (slope).A little less distortion is just a minor matter in my opinion. The main advantage, however, lies in the almost unlimited slope, which no voltage amplifier can offer, even if an equalizer is used. And that's exactly what makes the special sound...
Okay, I won't bother you anymore.
Doesn't that shorting ring also thwart some of the voice coil's ability to move the cone, too?Perhaps one complicating factor is that recent drivers of any quality tend to have shorting rings to minimize the inductance. Once upon a time that inductance variation may have tipped the performance in the favor of current drive.
A little, yes. But it has a drastic beneficial effect on distortion.Doesn't that shorting ring also thwart some of the voice coil's ability to move the cone, too?
Lot of marketing hype and simplified explanations ignoring how well voltage amplifiers work in the real world. An ideal voltage amplifier will deliver whatever current is needed, and an ideal current amplifier whatever voltage is required, with the end result on loudspeaker performance being comparable IME/IMO. The idea that their current amplifier perfectly controls the voice coil and all voltage amplifiers are fundamentally flawed when driving voice coils is an interesting stretch...I recently noticed that Avantgarde Acoustic claims to have/use somehing like a current source amplifier https://avantgarde-acoustic.de/en/sound-experience/itron/ for their super expensive horn speaker designs https://avantgarde-acoustic.de/en/products/trio-g3/
To me it looks more like marketing than serious engenering/science and the prices have one 0 too much for my taste. But maybe I am wrong and it at least sounds great for whatever exact technical reason. Presenting Ohm's Law and a high gloss picture of a 5 cent resistor at least looks suspicious to me.
They claim to be the first, however my 1983 Sony TA-F555ES is a Current Drive Integrated Amplifier, so Sony was actually the first. I do believe that Current Drive is superior to Voltage Drive.I recently noticed that Avantgarde Acoustic claims to have/use somehing like a current source amplifier https://avantgarde-acoustic.de/en/sound-experience/itron/ for their super expensive horn speaker designs https://avantgarde-acoustic.de/en/products/trio-g3/
The TA-F555ES used a current-signaling scheme internally to route the analog signal from the preamp to the power amp. The power amp is not a current-mode amplifier but a regular class-AB voltage-mode design AFAIK.They claim to be the first, however my 1983 Sony TA-F555ES is a Current Drive Integrated Amplifier, so Sony was actually the first. I do believe that Current Drive is superior to Voltage Drive.
Sony uses a voltage-to-current inverter. Their A.C.T. circuitry has a few stages. They use a Current Drive type attenuator between the pre-amp and power-amp stage. The pre-amp stage is also powered through a constant current shunt regulator.The TA-F555ES used a current-signaling scheme internally to route the analog signal from the preamp to the power amp. The power amp is not a current-mode amplifier but a regular class-AB voltage-mode design AFAIK.
Stereo Review did an equipment test report on the Sony TA-F555ES. It’s in the June 83 magazine. I found a .pdf version of it online. Some of the report I don’t understand, but I do understand THD, headroom, and dynamic range. I don’t understand the clipping they talk about, also the second and third order harmonics and some test they did with a phono cartridge to see how quiet the unit was.The TA-F555ES used a current-signaling scheme internally to route the analog signal from the preamp to the power amp. The power amp is not a current-mode amplifier but a regular class-AB voltage-mode design AFAIK.
For all intents and purposes, your amp is not current drive. We’ve been through this defore:They claim to be the first, however my 1983 Sony TA-F555ES is a Current Drive Integrated Amplifier, so Sony was actually the first. I do believe that Current Drive is superior to Voltage Drive.
