Computer Optimization of Room Acoustics
ernestcarl
I can only advise you to roll off the target curve below 80hz or so in DRC Designer.
Yes, effectively that would be better. But, as I said, there is no method in the GUI to manually change anything else other than the provided presets. From the help manual:
"Currently there is no manner to save and load custom targets, but your last defined target is saved between sessions and loaded when you restart the application."
schlager
You can easily drag the red dots around in the target designer and create your own curve. Make new dots just press mouse button.
ernestcarl
It was not obvious to me that you could do it due to the unresponsiveness of the program when clicking and dragging. But thank you for mentioning it once more which prompted me to re-check.
