Cambridge Audio Duo Phono Stage Review (Updated)
Rate this phono stage:
    Votes: 4 2.7%
    Votes: 10 6.7%
    Votes: 62 41.3%
    Votes: 74 49.3%
wemist01
Chicagoland
I think I've said this before but that's a great record you have as your avatar. Have you heard this, by another Sun Ra collaborator?
I remember grabbing both LPs when they were reissued around 20 years ago (wow) and I was working at a record store.
I missed it- love the rec- I will check that out!
Is that a function of the limitations of vinyl rather than the headphone stage?
The headphone amp itself. From what I recall, it is low power with high impedance.
This topic still confuses me.
Would you have some background article about this ?
I'd like to learn and understand it better.
The best reference I have is from this paper: https://www.aes.org/e-lib/browse.cfm?elib=2623
It is written by the famous Tom Holman. In there he computes the worst case level created by a cartridge:
AudioSceptic
Northampton, UK
The impedance was actually good.
Switching to headphone amplifier, the outcome is disappointing. Here it is with 300 Ohm load:
Cambridge Audio Duo Phono Pre-amp  Headphone Power at 300 Ohm Measurements.png
Even when you force the unit with far higher levels than any cartridge provides, you only get 10 milliwatts of power. My standard is 100 milliwatts here. With typical cartridges, you are likely to get single digit output power in milliwatts. Better have a sensitive headphone to get much value here.
Kind of odd is how quickly the graph flattens. Seems to be high level of noise there to dominate that way.
The situation is not much better with 33 ohm load:
Cambridge Audio Duo Phono Pre-amp  Headphone Power at 33 Ohm Measurements.png
You will be lucky to get 10 milliwatt output with any real cartridge.
There is good news however in the form of low output impedance:
sarumbear
I just realized for the first time that the phono preamp is another fundamental limitation on the SQ of vinyl. So, even everything else in your chain is perfectly transparent (the disc, the cartridge, etc.) the best SINAD you’re ever going to get with MC is ~-63 dB. That’s even worse than most speakers above ~300 hz. Am I missing something? What do measurements of vinyl test recordings deliver in best-case systems?
How do you measure the SINAD of a speaker, a passive device?
mightygrey
So, potentially no problem for more sensitive (+100dB)/high impedance headphones, eg HD600/HD800s if you're using vinyl as a source?
MediumRare
Chicago
Well, perhaps THD is the relevant measurement for the speakers since there is effectively no noise contributed by them directly, correct? So looking at the entire chain, noise will be coming from the source, the cartridge, the amplifiers, and the cables; distortion from all (excl. cables) plus the speakers. But if the preamp has worse THD than the rest that will be the primary source of distortion whereas often the speakers are the weak link, correct?
sarumbear
This was not answer to the question.
andrewskaterrr
STL
So, those super long Canare cables have nothing to do with the loading of your cartridge?!
I don’t think so, but I’m new to this? My Preamp is right next to my TT.
Cartridge > 3ft Technics stock cables > Phono Preamp 47kohm > 40ft Canare > Pre/Pro.
sarumbear
If you're getting stroppy, the answer is you use REW to compare the output of the speaker with the input, subtracting room noise.
Bravo. That is how you measure the SINAD of a speaker —not!
I’m not stroppy. I’m simply pointing to your sloppy use of a parameter. It’s up to you to learn.
sarumbear
Teach us, please.
To clarify, I was commenting to your following post.
SINAD is a parameter of active devices as passive devices generate no noise.
MediumRare
Chicago
And that’s why I clarified that THD was actually the relevant measure for a speaker.
sarumbear
My comment was to your earlier post, which is reposted, where you said SINAD.
sarumbear
SINAD combines noise and distortion.
As a speaker has no noise, SINAD is the wrong parameter. You do not measure the SINAD of a speaker.
That is the point I’m making.
Anyway, I’m off as we have polluted a review thread enough already. If you disagree please start a new thread and invite me.
