John Kenny
- Joined
- Mar 25, 2016
- Messages
- 568
- Likes
- 18
- Thread Starter
- #81
Regarding measurements & ASA streams
I believe the cues that we use to analyse sound into objects/streams are spatial, spectral & temporal cues. We analyse the relationship between these factors & as a result of this analysis form a perception of an auditory object. The auditory object is the end result of our analysis - the lumping together of certain spatial, spectral & temporal cues in the signal that our processing/analysis determines belong together & are emanating from the same source.
Streaming is this on-going analysis through time which is continually grouping these same auditory object cues together even though the object might change location, might change spectrally or might change temporally
Now this is happening for all auditory objects in the soundfield - so we have multiple auditory objects & multiple auditory streams that we are able to switch our attention between.
So if we go back to the ideas above about the perception of naturalness of auditory streams being because there is no fluctuation in the stream perception - they all remain firmly defined through the duration of the playback. A disturbance to a stream does not have to be a big change in spatial, spectral or temporal aspect - it does not have to be a change that lasts a long time (it can be very short). It's difficult to establish what is the minimum change in any one of these aspects that causes the disturbance of an auditory stream.
So, my view on measurements is that:
- firstly we need to be using test signals that are music
- we need to use techniques which will show any difference in these aspects throughout the whole music track
- we are not sure what depth we need to measure to in order to reveal the aspects above
So, I believe that techniques like AudioDiffmaker & Bibo01's/Tom's techniques of analysis are in the right direction
